[gdal-dev] Need help with geometric correction
Thu Jun 30 10:27:35 EDT 2011
On 11-06-30 10:20 AM, RSyaoxin wrote:
> Hi,all.
>       I want to correct the envisat N1 image, the gcps I used are come from
> the image.This image haven't geo-referenced information and projection,but
> it's GCPs have geo-referenced information.However I can not get correct
> results,the corrected image pixels are all zero.Here is my code:
>          psWarpOptions->nBandCount=0;
RSyaoxin,
I don't see anywhere that you establish the real list
of bands to be transferred.  Perhaps that is the problem?
In general the warp api is tricky to use, and if it is
sufficient for your needs to use a simplified interface
like GDALCreateAndReprojectImage() or GDALReprojectImage()
then I would encourage that.
Best regards,
