[gdal-dev] KML 2 SHP with attributes
Brian Case rush at winkey.org
Thu Jun 30 18:43:33 EDT 2011
Patrick,
Can you give an example of what tags your loosing?
are you using the kml or the libkml driver?
Brian
On Thu, 2011-06-30 at 15:30 -0600, Patrick Wild wrote:
> I am converting KML to .shp with OGR2ORG, however, due to the KML tags
> I am loosing my attributes. Does anyone have any experience with this?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
