[gdal-dev] Conversion from WGS84 to NAD83(EPSG:26912 - NAD83 / UTM zone 12N )
Delirious sumitpandey87 at gmail.com
Tue Mar 1 17:28:01 EST 2011
I am trying to convert a file in WGS format to Conversion from WGS84 to
NAD83(EPSG:26912 - NAD83 / UTM zone 12N ),
comman line input is
C:\Program Files (x86)\FWTools2.4.7>gdalwarp -t_srs EPSG:26912
G:\TestData\dem43m.tif G:\TestData\opt.tif
ERROR 1: Too many points (441 out of 441) failed to transform,
unable to compute output bounds.
I am giving above stated error.
gdalinfo of the input file is given below
Size is 1201, 1201
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (74.999583333333334,36.000416666666666)
Pixel Size = (0.000833333333333,-0.000833333333333)
Metadata:
  TIFFTAG_SOFTWARE=ERDAS IMAGINE
  TIFFTAG_XRESOLUTION=1
  TIFFTAG_YRESOLUTION=1
  TIFFTAG_RESOLUTIONUNIT=1 (unitless)
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  74.9995833,  36.0004167) ( 74d59'58.50"E, 36d 0'1.50"N)
Lower Left  (  74.9995833,  34.9995833) ( 74d59'58.50"E, 34d59'58.50"N)
Upper Right (  76.0004167,  36.0004167) ( 76d 0'1.50"E, 36d 0'1.50"N)
Lower Right (  76.0004167,  34.9995833) ( 76d 0'1.50"E, 34d59'58.50"N)
Center      (  75.5000000,  35.5000000) ( 75d30'0.00"E, 35d30'0.00"N)
Band 1 Block=64x64 Type=Int16, ColorInterp=Gray
Am i doing anything wrong?
Thanks
Sumit Pandey
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Conversion-from-WGS84-to-NAD83-EPSG-26912-NAD83-UTM-zone-12N-tp6078961p6078961.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
