[gdal-dev] Problems exporting numPY array to float Geotiff using OSGEO gdal python bindings
Christopher Barker Chris.Barker at noaa.gov
Wed Mar 2 16:08:44 EST 2011
On 3/2/11 8:49 AM, William Hudspeth wrote:
> Geotiff/Float32 image. While the script exports an image, all pixel
> My python code for the export is:
> floatNumPyArray=floatNumPyArray(numpy.float)
I don't know if this is your problem, but numpy.float is a 64 bitfloat,
you might try numpy.float32
Also, that call doesn't look right, do you want?
floatNumPyArray=floatNumPyArray.astype(numpy.float32)
That will convert a numpy array to the float32 type.
HTH,
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
