[gdal-dev] Re: gdal-dev Digest, Vol 82, Issue 4
Mike Leahy mgleahy at alumni.uwaterloo.ca
Thu Mar 3 05:41:29 EST 2011
Hi Jeff,
I was aware of the php_ogr module in the MS4W project...if I was working in
the Windows environment I would certainly consider that first for the ogr
functionality.  But it would also be nice to be able to get this in the Linux
environment...as well as to get the gdal and osr modules running.
I've updated the trac ticket I submitted
(http://trac.osgeo.org/gdal/ticket/3984) with an extra fix that was causing
segfaults when using the CreateGeometryFromWkt method in the ogr module.  The
gdal module still segfaults on startup, however...and I'm sure there's plenty
of other bits that will still need fixing.
Mike
> Date: Wed, 02 Mar 2011 10:46:02 -0400
> From: Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Subject: Re: [gdal-dev] Re: PHP bindings
> To: gdal-dev at lists.osgeo.org
> Message-ID: <4D6E582A.5080006 at gatewaygeomatics.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Just a quick note, that MapServer for Windows (MS4W) has always included
> the php_ogr extension...and if you are curious about where that project
> lives here is how to checkout the php_ogr code through CVS:
>   % cvs -d :pserver:cvsanon at cvs.maptools.org:/cvs/maptools/cvsroot login
>     Password: <enter>
>   % cvs -d :pserver:cvsanon at cvs.maptools.org:/cvs/maptools/cvsroot co
> php_ogr
> Hope that helps.  If you have questions about MS4W and its use of the
> php_ogr extension please use the MS4W mailing list (subscribe at
> http://lists.maptools.org/mailman/listinfo/ms4w-users)
> -jeff
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110303/be3967ad/attachment.html
