[gdal-dev] Polygon
Fri Mar 4 07:47:46 EST 2011
On 11-03-04 05:02 AM, Alexandre Leclerc wrote:
> Anybody can help me please ?
> I feel that the SHPWriteObject() write a bad way in the file.
> Do you think it could come from compiler ? I use Borland C++ 6
> When I edit the file in text editor it seems good, the length of the file is 1904
> But when I read file with SHPOpen() the psSHP->nFileSize attribute is 100…
> oddly this corresponds to the size of the header (shx).
> So I wonder if It comes from compiler or not…
> What do you think ?
Alexandre,
It sounds like you neglected to close the file so the header remains as
it was on creation.  Shapelib related questions are better sent to the
Shapelib mailing list.
Best regards,
