[gdal-dev] Visual Studio 2005 Debug mode error
Mateusz Loskot mateusz at loskot.net
Fri Mar 4 08:02:10 EST 2011
On 04/03/11 07:58, Robert Zermeno wrote:
 > This should not happen.  What is odd is if I build it in Release
 > mode, I do not get this issue.  However, that defeats the purpose
 > because I want to step through the code
> Anyone can confirm my problem? Solutions why only in Debug mode this occurs?
> Any suggestions would be great,
GDAL debug mode is not a real debug mode as expected by Visual C++
and it is a known issue which IMHO is a bug in GDAL, but there are
different opinions about that.
The only fix is:
http://lists.osgeo.org/pipermail/gdal-dev/2010-May/024683.html
You can find quite a number of of related tickets:
http://trac.osgeo.org/gdal/ticket/1647
http://trac.osgeo.org/gdal/ticket/540
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
