[gdal-dev] gdal and hdf-eos
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Mar 4 13:57:01 EST 2011
GDAL's HDF4 driver is built on top of NCSA HDF library.
On Sat, Mar 5, 2011 at 12:20 AM, Nikolaos Hatzopoulos <nhatzop at gmail.com>wrote:
> what extra libraries requires hdf4? i think only requires szip zlib and
> jpeg
> On Fri, Mar 4, 2011 at 10:03 AM, Chaitanya kumar CH <chaitanya.ch@
> gmail.com> wrote:
>> Matt,
>> If there is a work around it's better to avoid building. HDF4 requires
>> some extra libraries. They are probably missing.
>> On Fri, Mar 4, 2011 at 11:01 PM, Matt Funk <mafunk at nmsu.edu> wrote:
>>>  Hi Chaitanya,
>>> no, i didn't build it myself. I simply downloaded the self-installing
>>> package for gdal found at: http://www.lfd.uci.edu/~gohlke/pythonlibs/
>>> I am a little unfamiliar still with building stuff on windows, so i am
>>> not sure whether it's worth trying to build gdal and the python bindings
>>> from scratch or simply use h4toh5 called from the script.
>>> thanks
>>> matt
>>> On 3/3/2011 9:30 PM, Chaitanya kumar CH wrote:
>>> Matt,
>>> Did you build GDAL yourself? HDF4 format is not compiled by default. You
>>> can check if this by running the command "gdalinfo --formats". See if HDF4
>>> is in the output.
>>> http://www.gdal.org/frmt_hdf4.html
>>> On Fri, Mar 4, 2011 at 6:03 AM, Matt Funk <mafunk at nmsu.edu> wrote:
>>>>  Hi,
>>>> i am using python/gdal. I am trying to open a MODIS satellite file from
>>>> the Terra satellite (which is hdf4-eos format). Doing:
>>>>         ds = gdal.Open(file)
>>>>         drivertype=ds.GetDriver().LongName
>>>> returns
>>>>  ERROR 4:
>>>> `C:/tmp/SrcData/2010Data/MODISData/MOD03/MOD03.A2010002.1810.005.2010258062733.hdf'
>>>> not recognised as a supported file format.
>>>> Is this file format not supported?
>>>> thanks
>>>> matt
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Best regards,
>>> Chaitanya kumar CH.
>>> /tʃaɪθənjə/ /kʊmɑr/
>>> +91-9494447584
>>> 17.2416N 80.1426E
>> Best regards,
>> Chaitanya kumar CH.
>> /tʃaɪθənjə/ /kʊmɑr/
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110305/c83fb699/attachment-0001.html
