[gdal-dev] Polygon topology
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Mar 8 04:29:38 EST 2011
Simon,
You can use the OGRPolygon::getNumInteriorRings() method to get the number
of holes in an OGR polygon object.
On Tue, Mar 8, 2011 at 2:27 PM, Simon Lyngby Kokkendorff
<silyko at gmail.com>wrote:
> Hi List,
>   I am using ogr via the python bindings to construct various polygons.
> Here's just a simple question, to which someone might have some input. Is
> there anyway to determine the topology, i.e. the number of holes, of a
> polygon without e.g. having to export to WKT and examining the output
> string. There doesn't seem to be any methods exposed in the bindings to do
> this directly?
>   Cheers,
>   Simon Kokkendorff,
>   National Survey and Cadastre of Denmark
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110308/4ce6e7d0/attachment.html
