[gdal-dev] GDALWarpOperation.ChunkAndWarpImage slow on large tiffs
Wed Mar 9 14:00:12 EST 2011
On 11-03-09 01:46 PM, Radim Blazek wrote:
> Hi,
> GDALWarpOperation.ChunkAndWarpImage was reported to be extremly slow
> on larger geotiff (over 1GB). Is it possible that it is much slower
> with respect to GDALRasterIO()  even without reprojection? Should I
> return to 'manualy' reading data via GDALRasterIO() + fidling with
> data extents and cells alignement? I thought that GDAL
> ChunkAndWarpImage will do it even faster, possibly knowing better (?)
> various formats nature.
> Is there way to tune somehow performance? Currently no reprojection
> and GRA_NearestNeighbour.
Radim,
GDALWarpOperation is intended to be a high precision image resampler.
Within the constraints of doing this correctly it attempts to be fast,
but it will generally be quite a bit slower than direct RasterIO calls
and in some situations dramatically slower.  Particularly it is completely
inappropriate to use for radical downsampling.
Best regards,
