[gdal-dev] [OGR]Add a vertex to a feature
Mohamed Saâd HESSANE saad.hessane at gmail.com
Fri Mar 11 07:11:46 EST 2011
Thank's for your suggestion.
I test the OGRLayer::SetFeature() method, but it don't write the file after
that. I think the reason is what say Chaitanya (thank you) about the driver
which don't write until the handle is closed.
I think the best way is to write a CSV/VRT file.
I'm trying now.
2011/3/11 Even Rouault <even.rouault at mines-paris.org>
> Selon Mohamed Saād HESSANE <saad.hessane at gmail.com>:
> Mohamed,
> you can also use the OGRLayer::SetFeature() method to update an existing
> feature
> from a shapefile. But be aware that if you expand the geometry, its binary
> size
> will increase, so when you ask the geometry to be written by SetFeature(),
> the
> shape driver will write it at the end of the .shp file, so you might end up
> losing a lot of space. The same also applies to your current method of
> deleting
> and recreating a new feature.
> Best regards,
> Even
> > Hy list,
> > I' m trying to add on the fly points comming from GPS to a shapefile.
> > But the only way i find is to delete the feature from the shapefille, and
> > create a new feature with the added point. There's another way?
> > Thank you
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110311/f5403b69/attachment.html
