[gdal-dev] Many files over the network
Even Rouault even.rouault at mines-paris.org
Tue Mar 15 17:53:37 EDT 2011
Le mardi 15 mars 2011 22:48:16, Kyle Ellison a écrit :
> Even,
> I tried out the patch.  I was unable to actually try it in the 1.9 source
> since my environment uses the C# bindings and gdal18.dll.  So, I applied
> the patch manually to the 1.8 version I had.  That was not terribly
> difficult... mainly just different line numbers in geotiff.cpp.  Anyway,
> we got the performance of yesteryear back.  I would very much like you to
> commit that change to the main trunk if that is possible.  Thanks for your
> help on this.
Would you mind opening a GDAL Trac ticket to record this ? Thanks
> Best Regards,
> Kyle
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sent: Monday, March 14, 2011 5:41 PM
> To: gdal-dev at lists.osgeo.org
> Cc: Kyle Ellison
> Subject: Re: [gdal-dev] Many files over the network
> Kyle,
> you didn't mention which driver was in question. I guess this is GeoTIFF ?
> I've looked at the code of the driver and it appears that it loads the .rpb
> and .imd files at least since GDAL 1.6.0. The new thing in GDAL 1.8.0 is
> that it also tries to load the _rpc.txt file. Is it that small difference
> which causes the slowdown you observe ?
> In fact, setting GDAL_DISABLE_READDIR_ON_OPEN = TRUE might make things
> actually worse (w.r.t to that aspect of loading rpb/rpc/imd) since the
> driver has to really test the filesystem to look for the existence of the
> files, whereas by default it would rely on the papszSiblingsFile list.
> Anyway, I've attached a patch (against SVN trunk) that differs the loading
> of RPC and IMD until necessary (that is to say when GetMetadata() or
> GetMetadataItem() is called with "RPC" or "IMD" metadata domain, or when
> GetFileList() is called).
> Could you try it and report if it makes things better for you ?
> Another idea to solve the performance problem would be to use an alternate
> GDALOpen() where you could provide the papszSiblingFile list. If you read
> several files in the same directory, you could build the list one and
> provide it multiple times afterwards.
> Best regards,
> Even
> > Often, we need to open many raster files over a network connection
> > with thousands of other files residing in the same directory.
> > Previously, we were using version 1.7.0 of GDAL (from FW Tools), and
> > we used SetConfigOption("GDAL_DISABLE_READDIR_ON_OPEN", "TRUE")
> > to suppress the automatic search for sibling files.  This approach
> > served us well.
> > We upgraded to 1.8.0.  It was quite a bit slower opening the raster
> > files. I was able to get GDAL built in debug and stepped through the
> > code and discovered the following:
> > 1.       It searches for several files containing RPC metadata.
> > 2.       It searches for files for PAM as well.
> > I was able to use SetConfigOption("GDAL_PAM_ENABLED", "NO") to
> > suppress searching for PAM files.
> > However, I do not see a way to suppress searching for RPC metadata.
> > Does anyone know of a way to do this or other workarounds? If there is
> > no way to currently do this, is the community open to adding this option?
> > I apologize if this question has been posted previously, but I haven't
> > yet found a convenient way to search the archives.
> > Thanks,
> > Kyle
