[gdal-dev] Strange issue on debian squeeze
Marco Lechner - FOSSGIS e.V. marco.lechner at fossgis.de
Tue Mar 15 18:49:30 EDT 2011
I can reproduce this feature/bug on a freshly installed minimal squeeze
having nothing than downloaded gdal-source using
# ./configure --with-xerces=yes --with-xerces-inc=/usr/include/
--with-xerces-lib=/usr/lib/
and having installed
i libxerces-c-dev
v libxerces-c3-dev
v libxerces-c3-doc
v libxerces-c3-samples
i libxerces-c3.1
providing
libxerces-c-3.1.so
libxerces-c.a
libxerces-c.la
libxerces-c.so
in /usr/lib
and providing a bunch of *.hpp in subfolders of /usr/include/xercesc
Marco
Am 15.03.2011 20:15, schrieb Stephen Woodbridge:
> On 3/15/2011 2:23 PM, Chaitanya kumar CH wrote:
>> Oliver,
>> Can you confirm if you have xerces headers in /etc/include directory?
> That should probably say /usr/include directory, in case that was not
> obvious.
> -Steve
>> On Tue, Mar 15, 2011 at 11:13 PM, Oliver Burger
>> <oliver.bgr at googlemail.com <mailto:oliver.bgr at googlemail.com>> wrote:
>>     I have a strange problem installing gdal-1.8.0 on a debian
>> squeeze 64bit
>>     server.
>>     I'm using the following configure:
>>     ./configure --prefix=/usr/local/gdal-1.8.0 --with-xerces=yes
>>     Installed are:
>>     libxerces-c-dev             3.1.1-1+b1
>>     libxerces-c3.1              3.1.1-1+b1
>>     out of the debian repositories.
>>     And I'm getting the following output from configure:
>>     checking for Xerces C++ Parser headers in /usr/include and
>>     /usr/include/xercesc... not found
>>     checking for Xerces C++ Parser... no
>>     Xerces-C support:          no
>>     The same happens e.g. with expat and openjpeg.
>>     It's working all right on a Ubuntu 32bit and a Mandriva 32bit
>> machine.
>>     Do you have any idea, what is happening here?
>>     Thanks,
>>     Oliver
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> /tʃaɪθənjə/ /kʊmɑr/
>> +91-9494447584
>> 17.2416N 80.1426E
