[gdal-dev] openjpeg build configuration
Even Rouault
even.rouault at mines-paris.org
Thu Mar 17 13:23:40 EDT 2011
Selon Julien Michel <julien.michel at cnes.fr>:
Julien,
I've just diff'ed openjpeg.h of 1.3 and 1.4 and couldn't see much difference
between the 2. What make you believe that 1.4 supports tile access ? The
JP2OpenJPEG driver in particularly needs the opj_set_decode_area(),
opj_read_tile_header() and opj_decode_tile_data() API that are only found in v2
branch openjpeg.h
Best regards,
Even
> I hop on the thread since I am interested in openjpeg support too. It
> seems than those lines you pointed out are quite outdated, because
> openjpeg 1.4 released january 2011 provides tile-level reading. Is there
> any chance to build the gdal driver with openjpeg 1.4 ?
> Many thanks for your help,
> Best regards,
> Julien Michel
> Le 17/03/2011 17:23, Even Rouault a écrit :
> > Selon Brian Wilson<brian at wildsong.biz>:
> > Please read carefully the first lines of
> http://gdal.org/frmt_jp2openjpeg.html
> > for the explanation (and solution)
> >> I am trying to build 1.8.0 on Linux with openjpeg support.
> >> I can easily build and install openjpeg from source
> >> (oropenjpeg_v1_4_sources_r697) into /usr/local
> >> ./configure --with-openjpeg
> >> ./configure --with-openjpeg=/usr/local
> >> both result in
> >> OpenJPEG support: no
> >> I wiped my gdal-1.8.0 directory and unpacked a fresh copy to make sure
> >> nothing was cached.
> >> I can see this test in configure output
> >> checking for opj_decode_tile_data in -lopenjpeg... no
> >> which does not look promising. Is there a version compat problem?
> >> Brian
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Julien MICHEL
> CNES - DCT/SI/AP - BPI 1219
> 18, avenue Edouard Belin
> 31401 Toulouse Cedex 09 - France
> Tel: +33 561 282 894 - Fax: +33 561 283 109
