[gdal-dev] download.osgeo.org down?
Jorge Arévalo jorge.arevalo at deimos-space.com
Mon Mar 21 12:16:28 EDT 2011
2011/3/21 Frank Warmerdam <warmerdam at pobox.com>:
>> Hi,
>> Still unavailable from my network, in Spain. Same problem with
>> trac.osgeo.org since today. And
>> http://www.downforeveryoneorjustme.com/trac.osgeo.org
>> Says trac is down...
>> Should we report this to http://lists.osgeo.org/mailman/listinfo/sac ?
> Jorge,
> The Trac/SVN VM was down for circa 30 minutes this morning, but should be
> working fine again now. This problem was unrelated to the download.osgeo.org
> issue.
> For GDAL or other OSGeo systems problems I would encourage the following
> sequence:
> 1) Mention it in the #osgeo channel on IRC if you notice a problem.
> 2) wait 10-15 minutes for a response or for a transient problem to go away.
> 3) Submit a trac ticket at http://trac.osgeo.org/osgeo (with component
> set to "Systems Admin") and details on the issue.  Email about the ticket
> will be sent to the sac mailing list.
> Obviously problems with trac can't be reported via trac in which case
> email to the sac at lists.osgeo.org mailing list would be good.  Note that
> you need to be subscribed to the list to post to it.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
Hi Frank,
Ok, trac working for me. Thanks for the instructions!
Best regards,
Jorge Arévalo
Internet & Mobilty Division, DEIMOS
http://es.linkedin.com/in/jorgearevalo80
http://mobility.grupodeimos.com/
http://gis4free.wordpress.com
http://geohash.org/ezjqgrgzz0g
