[gdal-dev] KML conversion and attributes
brian rush at winkey.org
Tue Mar 22 12:43:31 EDT 2011
Sbastien,
Yes i was able to create the shape file. I see the libkml in your
--formats output So that appears to be good
Perhaps you could paste back the output of ogrinfo -al testy.kml?
Brian
On Tue, 2011-03-22 at 08:40 +0000, Favre, Sebastien wrote:
> Hello Brian,
> Thank you for your response. I have correctly received your first email !
> I have tried to remove <Folder> and </Folder> without success : the output Shapefile does not contain ScaleRank, FeatureCla, Name1 and Name2 attributes.
> Did you manage to generate a Shapefile with the extra attributes ?
> Sbastien
> -----Message d'origine-----
> De : gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de brian
> Envoy : lundi 21 mars 2011 18:41
>  : Favre, Sebastien
> Cc : gdal-dev at lists.osgeo.org
> Objet : Re: [gdal-dev] KML conversion and attributes
> Sbastien
> try removeing the <Folder> and </Folder> from the kml
> if you want seperate schemas for different layers you need seperate documents not seperate folders
> Brian
> rush at octopi ~ $ ogrinfo -al testy.kml
> INFO: Open of `testy.kml'
>       using driver `LIBKML' successful.
> Layer name: testy
> Geometry: Unknown (any)
> Feature Count: 1
> Extent: (103.620011, 51.460012) - (109.929807, 55.730914) Layer SRS WKT:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         TOWGS84[0,0,0,0,0,0,0],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0,
>         AUTHORITY["EPSG","8901"]],
>     UNIT["degree",0.0174532925199433,
>         AUTHORITY["EPSG","9108"]],
>     AUTHORITY["EPSG","4326"]]
> description: String (0.0)
> timestamp: DateTime (0.0)
> begin: DateTime (0.0)
> end: DateTime (0.0)
> altitudeMode: String (0.0)
> tessellate: Integer (0.0)
> extrude: Integer (0.0)
> visibility: Integer (0.0)
> Description: String (0.0)
> ScaleRank: Integer (0.0)
> FeatureCla: String (0.0)
> Name1: String (0.0)
> Name2: String (0.0)
> OGRFeature(testy):1
>   Name (String) = 0
>   description (String) = Lake
>   timestamp (DateTime) = (null)
>   begin (DateTime) = (null)
>   end (DateTime) = (null)
>   altitudeMode (String) = (null)
>   tessellate (Integer) = -1
>   extrude (Integer) = -1
>   visibility (Integer) = -1
>   Name (String) = (null)
>   Description (String) = (null)
>   ScaleRank (Integer) = 0
>   FeatureCla (String) = (null)
>   Name1 (String) = 0
>   Name2 (String) = POLYGON
>   Style =
>   POLYGON ((106.579985793079118 52.799981594445541,106.539988234485207
> 52.939998887740373,107.080006951935303
> 53.180010077519981,107.299993524201795
> 53.379997870489532,107.599975213656109
> 53.519989325568218,108.039948358189122
> 53.859968573616456,108.37997928266966
> 6 54.259995835987837,109.052703078245258
> 55.027597561251326,109.193469679808317
> 55.535602728896592,109.506990594523131
> 55.730913804743722,109.92980716353523
> 55.712956244522303,109.700002069133262
> 54.980003567110515,109.660004510539352 54.719993598033952,109.479963
> 820434477 54.339990953175658,109.319973586058836
> 53.819996853238692,109.220031366006367
> 53.619983222052994,108.999993117307554
> 53.780025132860928,108.600017531368451
> 53.439994208380398,108.800005324338002
> 53.379997870489532,108.760007765744092 53.200008856816936,1
> 08.459974399857487 53.140012518926071,108.179991489700114
> 52.799981594445541,107.79996300662566
> 52.579995022179034,107.319992303498765
> 52.420004787803393,106.64003380740229
> 52.320010891318617,106.100015089952194
> 52.039976304728967,105.740037062607001 51.7599933945
> 71595,105.240015903750844 51.520008043008133,104.819989862082508
> 51.460011705117267,104.300021600361674
> 51.500009263711178,103.760002882911607
> 51.600003160195953,103.620011427832907
> 51.73999461527464,103.859996779396369
> 51.85998729105637,104.399963820414143 51.859
> 98729105637,105.05997521364597 52.000004584351203,105.480001255314306
> 52.280013332724707,105.980022414170463
> 52.519998684288169,106.260005324327835
> 52.619992580772944,106.579985793079118 52.799981594445541))
> On Mon, 2011-03-21 at 10:29 +0000, Favre, Sebastien wrote:
> > Hello to all,
> > I try to convert the following KML file into Shapefile format.
> > <?xml version="1.0" encoding="utf-8" ?>
> > <kml xmlns="http://www.opengis.net/kml/2.2">
> > <Document><Folder><name>110m_lakes</name>
> > <Schema name="110m_lakes" id="110m_lakes">
> >                 <SimpleField name="Name" type="string"></SimpleField>
> >                 <SimpleField name="Description"
> >                 <SimpleField name="ScaleRank"
> > type="int"></SimpleField>
> >                 <SimpleField name="FeatureCla"
> >                 <SimpleField name="Name1" type="string"></SimpleField>
> >                 <SimpleField name="Name2" type="string"></SimpleField>
> > </Schema>
> >   <Placemark>
> >                 <name>0</name>
> >                 <description>Lake</description>
> >   <Style><LineStyle><color>ff0000ff</color></LineStyle>
> > <PolyStyle><fill>0</fill></PolyStyle></Style>
> >                 <ExtendedData><SchemaData schemaUrl="#110m_lakes">
> >                                <SimpleData name="Name">0</SimpleData>
> >                                <SimpleData
> > name="Description">Lake</SimpleData>
> >                                <SimpleData name="ScaleRank">Lake
> > Baikal</SimpleData>
> >                                <SimpleData name="Name1">0</SimpleData>
> >                                <SimpleData
> > name="Name2">POLYGON</SimpleData>
> >                 </SchemaData></ExtendedData>
> > <Polygon><outerBoundaryIs><LinearRing><coordinates>106.57998579307912,52.799981594445541 106.53998823448521,52.939998887740373 107.0800069519353,53.180010077519981 107.2999935242018,53.379997870489532 107.59997521365611,53.519989325568218 108.03994835818912,53.859968573616456 108.37997928266967,54.259995835987837 109.05270307824526,55.027597561251326 109.19346967980832,55.535602728896592 109.50699059452313,55.730913804743722 109.92980716353523,55.712956244522303 109.70000206913326,54.980003567110515 109.66000451053935,54.719993598033952 109.47996382043448,54.339990953175658 109.31997358605884,53.819996853238692 109.22003136600637,53.619983222052994 108.99999311730755,53.780025132860928 108.60001753136845,53.439994208380398 108.800005324338,53.379997870489532 108.76000776574409,53.200008856816936 108.45997439985749,53.140012518926071 108.17999148970011,52.799981594445541 107.79996300662566,52.579995022179034 107.31999230349876,52.420004787803393 106.64003380740229,52.320010891318617 106.10001508995219,52.039976304728967 105.740037062607,51.759993394571595 105.24001590375084,51.520008043008133 104.81998986208251,51.460011705117267 104.30002160036167,51.500009263711178 103.76000288291161,51.600003160195953 103.62001142783291,51.73999461527464 103.85999677939637,51.85998729105637 104.39996382041414,51.85998729105637 105.05997521364597,52.000004584351203 105.48000125531431,52.280013332724707 105.98002241417046,52.519998684288169 106.26000532432784,52.619992580772944 106.57998579307912,52.799981594445541</coordinates></LinearRing></outerBoundaryIs></Polygon>
> >   </Placemark>
> > </Folder></Document></kml>
> > I use the command line for that : ogr2ogr -f "ESRI Shapefile" lake.shp
> > lake.kml
> > The problem is I only get the attributes Name and Descriptio (after
> > trunk) in the output Shapefile.
> > Attributes ScaleRank, Name12 and Name2 are missing.
> > Do you have any explanation ?
> > Please note,  I have installed the LIBKML driver In GDAL/OGR (thanks
> > to Frank for its help) :
> > D:\Data\ >ogr2ogr --formats
> > Supported Formats:
> >   -> "ESRI Shapefile" (read/write)
> >   -> "MapInfo File" (read/write)
> >   -> "UK .NTF" (readonly)
> >   -> "SDTS" (readonly)
> >   -> "TIGER" (read/write)
> >   -> "S57" (read/write)
> >   -> "DGN" (read/write)
> >   -> "VRT" (readonly)
> >   -> "REC" (readonly)
> >   -> "Memory" (read/write)
> >   -> "BNA" (read/write)
> >   -> "CSV" (read/write)
> >   -> "GML" (read/write)
> >   -> "GPX" (read/write)
> >   -> "LIBKML" (read/write)
> >   -> "KML" (read/write)
> >   -> "GeoJSON" (read/write)
> >   -> "GMT" (read/write)
> >   -> "ODBC" (read/write)
> >   -> "PGeo" (readonly)
> >   -> "MSSQLSpatial" (read/write)
> >   -> "PCIDSK" (read/write)
> >   -> "XPlane" (readonly)
> >   -> "AVCBin" (readonly)
> >   -> "AVCE00" (readonly)
> >   -> "DXF" (read/write)
> >   -> "Geoconcept" (read/write)
> >   -> "GeoRSS" (read/write)
> >   -> "GPSTrackMaker" (read/write)
> >   -> "VFK" (readonly)
> >   -> "PGDump" (read/write)
> >   -> "GPSBabel" (read/write)
> >   -> "SUA" (readonly)
> >   -> "OpenAir" (readonly)
> >   -> "PDS" (readonly)
> >   -> "HTF" (readonly)
> >   -> "AeronavFAA" (readonly)
> > Thanks in advance for your help.
> > Sbastien
> > Ce courrier lectronique et toutes les pices ventuellement jointes qu'il contient sont CONFIDENTIELS et destins exclusivement  l'usage de leur destinataire. Si une erreur de transmission ou une adresse errone a mal dirige ce courrier, merci d'en informer l'expditeur en lui faisant une rponse par courrier lectronique ds rception. Si vous n'tes pas le destinataire de ce courrier, vous ne devez pas l'utiliser, le conserver, en faire tat, le distribuer, le copier, l'imprimer ou en rvler le contenu  une tierce partie.
> > Ce courrier lectronique est  usage strictement informatif et ne saurait engager de quelque manire que ce soit SPOT IMAGE SA, ni ses filiales.
> > This e-mail and any attachments hereto are CONFIDENTIAL and intended solely for the use of the addressee. If you have received this e-mail in error please send it back to the person that sent it to you.
> > If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
> > This email is for information only and will not bind SPOT IMAGE SA in any contract or obligation, nor its subsidiaries.
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Ce courrier lectronique et toutes les pices ventuellement jointes qu’il contient sont CONFIDENTIELS et destins exclusivement  l’usage de leur destinataire. Si une erreur de transmission ou une adresse errone a mal dirige ce courrier, merci d’en informer l’expditeur en lui faisant une rponse par courrier lectronique ds rception. Si vous n’tes pas le destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en faire tat, le distribuer, le copier, l’imprimer ou en rvler le contenu  une tierce partie.
