[gdal-dev] GDAL autotest (mrsid_1) crashing on Win64
Tamas Szekeres szekerest at gmail.com
Wed Mar 23 11:36:01 EDT 2011
Even,
According to the buildlog at http://vbkto.dyndns.org/sdk/  r21980 was still
OK, and r21988 was already wrong.
Best regards,
Tamas
2011/3/23 Even Rouault <even.rouault at mines-paris.org>
> Selon Tamas Szekeres <szekerest at gmail.com>:
> Tamas,
> Indeed there have been recent changes. You might want to drop a note about
> that
> to Kirk in ticket http://trac.osgeo.org/gdal/ticket/4002 . After latest
> fixes
> from Kirk and me, I no longer see problems under Linux however.
> I don't know which version of the GeoDSDK you are using. But, at least
> under
> Linux, there's an ABI incompatibility of GeoSDSK v7 with latest libgeotiff
> (due
> to the addition of new fields in geo_normalize.h) that cause crashes. But
> the
> libgeotiff change is a bit older than the MrSID driver one, so it would be
> surprising that Kirk changes have an impact on that. Under Linux, using
> version
> 8 solves that issue. If you revert only the changes of the MrSID driver (to
> what
> it was before r21974), what happens ?
> Best regards,
> Even
> > Hi All,
> > I'm experiencing permanent crash in the mrsid_1 autotest on the Win64
> builds
> > of http://vbkto.dyndns.org/sdk/. This problem may be related due to a
> recent
> > change (in 2-3 days).
> > Any ideas about the reason?
> > Best regards,
> > Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110323/925aae30/attachment.html
