[gdal-dev] accessing zip files by URL
Joaquim Luis jluis at ualg.pt
Thu Mar 24 19:37:38 EDT 2011
I understand all that and even though I'm a win user I always try to be
very careful with case names (basically, I avoid upper cases). But while
it is easy to see the case of the real file (I know that urls are case
sensitive) it's not so easy so clear to know what's inside a compressed
file on the internet because if you know it it means one already have it
in the local file system.
Since is up to gdal to read the contents of the compressed file and get
its data (NOT the file itself) it seams to me that there would be no
danger in being case insensitive.
But this is really a minor point (once you know why it didn't work on
the first time), I know.
Joaquim
>> Even,
>> Still one further point on this matter. This works fine with the
>> promised slowness (fair enough)
>> gdalinfo
>> /vsitar/vsicurl/http://edcftp.cr.usgs.gov/pub/data/gtopo30/global/w020n90.t
>> ar.gz/W020N90.DEM
>> but the file name is case dependent. I mean, this doesn't work
>> gdalinfo
>> ar.gz/w020n90.dem
>> I'm not sure what is the right thing to do here but as a Win (and
>> occasional Mac or Linus)  user I guess that I was expecting no case
>> dependency.
> GDAL's behaviour with the case sensitivity in a virtual file path is completely
> OS independant.
> Actually filenames in archives are case sensitive. I have just made a .tar.gz
> with 2 filenames that only differ by their case :
> $ tar tvzf aa.tar.gz
> -rw-r--r-- even/even         2 2011-03-24 23:54 Aa
> -rw-r--r-- even/even         3 2011-03-24 23:54 aa
> And the same with a zip file :
> $ unzip -l aa.zip
> Archive:  aa.zip
>    Length      Date    Time    Name
>          5                     2 files
> Admitedly a windows user will not be very happy when he uncompresses those
> archives in a "real" filesystem ;-)
> I will also note that URLs are also case sensitive.
> http://edcftp.cr.usgs.gov/pub/data/gtopo30/global/w020n90.tar.gz is a valid
> URL, but http://edcftp.cr.usgs.gov/pub/data/gtopo30/global/w020n90.tar.gZ is
> not
> So I'm not sure that there's really a point in making the lookup of filenames
> inside the archive case insensitive.
>> Joaquim
