[gdal-dev] OGR2OGR options -select and -where together
Christy Nieman cnieman at dmsolutions.ca
Fri Mar 25 09:46:54 EDT 2011
Sorry, wrong order for the source and destination files.  Should be
output.shp then input.shp
C
On 03/25/2011 09:45 AM, Christy Nieman wrote:
> Hello,
> You can indeed use both -select and -where together together.  For
> example
> ogr2ogr -select field1,field2,field3 -where "field1 = value OR field2
> = anotherValue" input.shp output.shp
> Best regards,
> Christy
> On 03/25/2011 09:38 AM, Luiz Motta wrote:
>> Devs,
>> I would like have the subset of data, by filters of field (-select)
>> and attributes(-where), using OGR2OGR.
>> My enviroment is:
>> - Windows XP
>> - GDAL from OSGEO4W
>> - Version: GDAL 1.8.0, released 2011/01/12
>> At the moment, i can only make subset(field and attribute) by call
>> separate of OGR2OGR.
>> Has one manner to use options  "select" and "where" in the same call
>> OGR2OGR  ?
>> Next, my tests  to make subsets:
>> 1) Source data:
>> http://www.dpi.inpe.br/prodesdigital/dadosn/2009/PDigital2009_23367_shp.zip
>> 2) Show info:
>> 2.1) Summary
>> ogrinfo -so Prodes2009_23367.shp Prodes2009_23367
>> 2.2) Subset features (see -where)
>> ogrinfo -q -geom=NO -where "ano = '2009' and class_name =
>> 'DESFLORESTAMENTO'"  Prodes2009_23367.shp Prodes2009_23367 | more
>> 3) Subset data
>> 3.1) Filter by field(-select) and attribute(-where) ->  Empty data
>> output
>> ogr2ogr -f "ESRI Shapefile" -select "ano" -where "ano = '2009' and
>> class_name = 'DESFLORESTAMENTO'" filter_select_where.shp
>> ogrinfo -so filter_select_where.shp filter_select_where
>> * Feature Count = 0
>> 3.2) Filter by field(-select)
>> ogr2ogr -f "ESRI Shapefile" -select "ano" filter_select.shp
>> ogrinfo -so filter_select.shp filter_select
>> 3.3) Filter by attribute(-where)
>> ogr2ogr -f "ESRI Shapefile" -where "ano = '2009' and class_name =
>> 'DESFLORESTAMENTO'" filter_where.shp Prodes2009_23367.shp
>> ogrinfo -so filter_where.shp filter_where
>> Regards,
>> Luiz Motta
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
