[gdal-dev] OGR2OGR options -select and -where together
Christy Nieman cnieman at dmsolutions.ca
Fri Mar 25 10:50:43 EDT 2011
Sorry, I wanted to provide more info, but I wanted to compile 1.8.0
before expanding on this (I was running a trunk version from before
1.8.0's release).  I was going to suggest that you could use the -sql
parameter with an sql query, however I was unable to get this to work
with 1.8.0 either, though it worked in 1.7.x.  I also wanted to read
through the release notes to see if there was something obvious I
missed, but didn't see anything.  Anyone else encountered this problem?
On 03/25/2011 10:17 AM, Luiz Motta wrote:
> Thank's  Christy.
> The idea is report this problem, or verify , if i am using correct
> form the OGR2OGR.
> Luiz
> 2011/3/25 Christy Nieman<cnieman at dmsolutions.ca>:
>> And apparently I'm half asleep this morning.  Didn't see your examples of
>> what you've tried.  Sorry.  I tried your 3.1 ogr2ogr with your data and got
>> 754 features returned with an older version of GDAL (1.7 I believe), but 0
>> with 1.8 also.
>> On 03/25/2011 09:46 AM, Christy Nieman wrote:
>>> Sorry, wrong order for the source and destination files.  Should be
>>> output.shp then input.shp
>>> C
>>> On 03/25/2011 09:45 AM, Christy Nieman wrote:
>>>> Hello,
>>>> You can indeed use both -select and -where together together.  For
>>>> example
>>>> ogr2ogr -select field1,field2,field3 -where "field1 = value OR field2 =
>>>> anotherValue" input.shp output.shp
>>>> Best regards,
>>>> Christy
>>>> On 03/25/2011 09:38 AM, Luiz Motta wrote:
>>>>> Devs,
>>>>> I would like have the subset of data, by filters of field (-select)
>>>>> and attributes(-where), using OGR2OGR.
>>>>> My enviroment is:
>>>>> - Windows XP
>>>>> - GDAL from OSGEO4W
>>>>> - Version: GDAL 1.8.0, released 2011/01/12
>>>>> At the moment, i can only make subset(field and attribute) by call
>>>>> separate of OGR2OGR.
>>>>> Has one manner to use options  "select" and "where" in the same call
>>>>> OGR2OGR  ?
>>>>> Next, my tests  to make subsets:
>>>>> 1) Source data:
>>>>> http://www.dpi.inpe.br/prodesdigital/dadosn/2009/PDigital2009_23367_shp.zip
>>>>> 2) Show info:
>>>>> 2.1) Summary
>>>>> ogrinfo -so Prodes2009_23367.shp Prodes2009_23367
>>>>> 2.2) Subset features (see -where)
>>>>> ogrinfo -q -geom=NO -where "ano = '2009' and class_name =
>>>>> 'DESFLORESTAMENTO'"  Prodes2009_23367.shp Prodes2009_23367 | more
>>>>> 3) Subset data
>>>>> 3.1) Filter by field(-select) and attribute(-where) ->    Empty data
>>>>> output
>>>>> ogr2ogr -f "ESRI Shapefile" -select "ano" -where "ano = '2009' and
>>>>> class_name = 'DESFLORESTAMENTO'" filter_select_where.shp
>>>>> ogrinfo -so filter_select_where.shp filter_select_where
>>>>> * Feature Count = 0
>>>>> 3.2) Filter by field(-select)
>>>>> ogr2ogr -f "ESRI Shapefile" -select "ano" filter_select.shp
>>>>> ogrinfo -so filter_select.shp filter_select
>>>>> 3.3) Filter by attribute(-where)
>>>>> ogr2ogr -f "ESRI Shapefile" -where "ano = '2009' and class_name =
>>>>> 'DESFLORESTAMENTO'" filter_where.shp Prodes2009_23367.shp
>>>>> ogrinfo -so filter_where.shp filter_where
>>>>> Regards,
>>>>> Luiz Motta
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
