[gdal-dev] GDAL autotest (mrsid_1) crashing on Win64
Tamas Szekeres szekerest at gmail.com
Sun Mar 27 11:06:05 EDT 2011
I did some investigations related to the Win64 problem, but I have no clues
how to get further with this problem.
I've used Unified_DSDK_8.0_win64-vc9 and the MSVC 2008x64 compiler and even
the following code is causing heap corruption when running the mrsid
autotest:
LTIOFileStream *ltiofs = new LTIOFileStream();
if ( ltiofs )
        delete ltiofs;  // heap corruption here
HEAP[python.exe]: Invalid Address specified to RtlFreeHeap(
00000000025E0000, 0000000001E97610 )
Windows has triggered a breakpoint in python.exe.
This issue seems to be related to the changes
r21974<http://trac.osgeo.org/gdal/changeset/21974>
Best regards,
Tamas
2011/3/23 Kirk McKelvey <kmckelvey at lizardtech.com>
> Strange, nothing happened to the driver code in that range.  I will bring
> up a 64-bit build and see if I can debug it.  Am I correct that your 32-bit
> builds are passing this test?
> ________________________________________
> De : gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org]
> de la part de Tamas Szekeres [szekerest at gmail.com]
> Date d'envoi : mercredi 23 mars 2011 08:36
> À : Even Rouault
> Cc : gdal-dev
> Objet : Re: [gdal-dev] GDAL autotest (mrsid_1) crashing on Win64
> Even,
> According to the buildlog at http://vbkto.dyndns.org/sdk/  r21980 was
> still OK, and r21988 was already wrong.
> Best regards,
> Tamas
> 2011/3/23 Even Rouault <even.rouault at mines-paris.org<mailto:
> even.rouault at mines-paris.org>>
> Selon Tamas Szekeres <szekerest at gmail.com<mailto:szekerest at gmail.com>>:
> Tamas,
> Indeed there have been recent changes. You might want to drop a note about
> that
> to Kirk in ticket http://trac.osgeo.org/gdal/ticket/4002 . After latest
> fixes
> from Kirk and me, I no longer see problems under Linux however.
> I don't know which version of the GeoDSDK you are using. But, at least
> under
> Linux, there's an ABI incompatibility of GeoSDSK v7 with latest libgeotiff
> (due
> to the addition of new fields in geo_normalize.h) that cause crashes. But
> the
> libgeotiff change is a bit older than the MrSID driver one, so it would be
> surprising that Kirk changes have an impact on that. Under Linux, using
> version
> 8 solves that issue. If you revert only the changes of the MrSID driver (to
> what
> it was before r21974), what happens ?
> Best regards,
> Even
> > Hi All,
> > I'm experiencing permanent crash in the mrsid_1 autotest on the Win64
> builds
> > of http://vbkto.dyndns.org/sdk/. This problem may be related due to a
> recent
> > change (in 2-3 days).
> > Any ideas about the reason?
> > Best regards,
> > Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110327/630f222a/attachment.html
