[gdal-dev] strange behaviour of the python bindings in a seldom case
    Matthieu Rigal
    rigal at rapideye.de
    Mon Mar 28 11:53:47 EDT 2011
Dear GDAL heroes,
I have encountered a very strange behaviour of the python bindings. I am using
version 1.7.3 with Python 2.6 on a OpenSuse 11 64bits.
We developped an in-house C++ python accessor and I get a segmentation fault
at a very bizarre place.
I am launching following minimal python script :
#!/usr/local/bin/python
import sys
from osgeo import gdal, ogr
print sys.argv
if I launch it from this minimal shell script, everything goes fine :
python sample1.py 1
python sample1.py 2
But if I launch it through our C++ accessor, I got systematically a
"segmentation fault" WHEN CALLING THE SCRIPT A SECOND TIME, that is located at
the import step.
Stranger, if I replace the double load "gdal, ogr", by gdal or ogr, the
scripts are working as many as I want !!! (gdal+osr crashes also, whereas
ogr+osr does not !)
It crashes only at the second run when loading gdal AND ogr... and trying to
repeat the error via a shellscript or via inline commands does not point the
same problems...
I tried to use the sys.modules.items() to see if still some modules were
present, I tried to use the reload() for the modules and I could not solve the
problem...
The fact that it is crashing only from our launcher could indicate that here
comes the error from, but I could not find anything... maybe I could run a
"clean loaded module" command on the C++/Python interface, which I did not
found now...
(The C++/interface is a part of a much bigger processing pacakage, therefore I
can not give easily a sample)
But also, the fact that this only occurs with >1 osgeo packages (I tried
several other ones) indicates that there might be a problem on this side, or
am I wrong ?
Any help or hint on something I could have forgotten would be appreciated !
Best Regards,
Matthieu Rigal
RapidEye AG
Molkenmarkt 30
14776 Brandenburg an der Havel
Germany
Follow us on Twitter! www.twitter.com/rapideye_ag
Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
Management Board/Vorstand: Wolfgang G. Biedermann,
                           Frederik Jung-Rothenhaeusler
Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates:
Juergen Breitkopf
Commercial Register/Handelsregister Potsdam HRB 17 796
Tax Number/Steuernummer: 048/100/00053
VAT-Ident-Number/Ust.-ID: DE 199331235
DIN EN ISO 9001 certified
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
The information in this e-mail is intended for the named recipients
only. It may contain privileged and confidential information. If you
have received this communication in error, any use, copying or
dissemination of its contents is strictly prohibited. Please erase all
copies of the message along with any included attachments and notify
RapidEye AG or the sender immediately by telephone at the number
indicated on this page.
