[gdal-dev] Using MEM driver to output to an gtiff in /vsimem/
Bborie Park bkpark at ucdavis.edu
Tue Mar 29 18:39:27 EDT 2011
>> What does not seem to work is if I use CreateCopy with a /vsimem/ path.
>> rtn_ds = GDALCreateCopy(
>> 	rtn_drv,
>> 	"/vsimem/out.tif",
>> 	src_ds,
>> 	FALSE,
>> 	options,
>> 	NULL,
>> 	NULL
> -->  Here, you must close the dataset so it to be properly flushed before
> getting the buffer.
Thanks Even!  That simple solution works for me.
-bborie
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
