[gdal-dev] RGB bands
Emilio de Torres Fernández emilio.detorres at fueca.es
Wed Mar 30 03:44:04 EDT 2011
Thanks Chaitanya,
I did
	$ gdal_translate src.tif dst.tif -b 3 -b 2 -b 1 co PHOTOMETRIC=RGB
to create the new GeoTIFF with the order of the bands modified and the
color interpretation assigned to them.
Best regards.
El mar, 29-03-2011 a las 17:13 +0530, Chaitanya kumar CH escribió:
> Emilio,
> You can create a new GeoTIFF with just the three bands you need using
> gdal_translate utility with the -b option.
> http://www.gdal.org/gdal_translate.html
> 2011/3/29 Emilio de Torres Fernández <emilio.detorres at fueca.es>
>         Hello,
>         I have a GeoTIFF image with 5 bands and I need to transform it
>         to a
>         GeoTIFF with these values:
>         - Red = band 3.
>         - Green = band 2.
>         - Blue = band 1.
>         How can I do that? Would I need to delete bands 4 and 5?
>         Best regards.
>         _______________________________________________
>         gdal-dev mailing list
>         gdal-dev at lists.osgeo.org
>         http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
