[gdal-dev] Setting "INIT_DEST" to nan on windows
    Even Rouault
    even.rouault at mines-paris.org
    Thu May  5 14:21:59 EDT 2011
Le mercredi 04 mai 2011 00:40:42, Kyle Shannon a écrit :
> I am using AutoCreateWarpedVRT to warp a dataset.  I grab the the source
> nodata for a band using
> double noData = poBand->GetNoDataValue( &pbSuccess );
> which returns 1.#QNAN00000000... on windows.
> I then try to set the INIT_DEST with this using
> psWarpOptions->papszWarpOptions =
>         CSLSetNameValue( psWarpOptions->papszWarpOptions,
>                  "INIT_DEST", CPLSPrintf( "%lf", noData ) );
> This works on linux when it returns nan(0x8000000000000), but not on
> windows, is there a different string I need to set in the warp options?
Those NaN values are generally a nighmare to deal with...
But a quick look at :
    const char *pszInitDest = CSLFetchNameValue( psOptions->papszWarpOptions,
                                                 "INIT_DEST" );
    if( pszInitDest != NULL && !EQUAL(pszInitDest, "") )
        char **papszInitValues =
            CSLTokenizeStringComplex( pszInitDest, ",", FALSE, FALSE );
        int nInitCount = CSLCount(papszInitValues);
        for( iBand = 0; iBand < psOptions->nBandCount; iBand++ )
            double adfInitRealImag[2];
            GByte *pBandData;
            const char *pszBandInit =
papszInitValues[MIN(iBand,nInitCount-1)];
            if( EQUAL(pszBandInit,"NO_DATA")
                && psOptions->padfDstNoDataReal != NULL )
                adfInitRealImag[0] = psOptions->padfDstNoDataReal[iBand];
                adfInitRealImag[1] = psOptions->padfDstNoDataImag[iBand];
            else
                CPLStringToComplex( pszBandInit,
                                    adfInitRealImag + 0, adfInitRealImag + 1);
Make me believe that one way is to assign the value(s) of the
padfDstNoDataReal[] array of psWarpOptions with the noData (NAN) value and set
INIT_DEST to the "NO_DATA" string.
> Thanks.
>  * Kyle Shannon
>  * ksshannon at gmail.com
