[gdal-dev] gdal reading in grib values in awrong state?
Matt Funk mafunk at nmsu.edu
Thu May 5 18:05:30 EDT 2011
Yup,
that was it. I should have looked a little closer i suppose ...
thanks
matt
On 5/5/2011 3:09 PM, Brian Case wrote:
> Matt,
> At a quick glance I would say pygrib is outputting in kelvin and gdal
> Celsius. also it looks like there not in the same order.
> Brian
> On Thu, 2011-05-05 at 14:57 -0600, mafunk at nmsu.edu wrote:
>> Hi,
>> i am a little confused. I am using the gdal/python and trying to read
>> values from a grib file (i can email the file if needed). I am using
>> pygrib to compare against. I do this with the following code:
>> import struct
>> import pygrib
>> from osgeo import gdal
>> from osgeo import ogr
>> from osgeo import osr
>> from osgeo import gdal_array
>> from osgeo import gdalconst
>> from osgeo.gdalconst import *
>> import numpy as np
>> from numpy import *
>> #path = "../Data"
>> #filename = "%s/ds.temp.bin" % (path)
>> filename = "ds.temp.bin"
>> print "\n\nTesting with pygrib, opening file: %s\n" % (filename)
>> grbs = pygrib.open(filename)
>> rows = -1
>> cols = -1
>> grbs.seek(0)
>> for grb in grbs:
>>     print "grb:"
>>     grb
>>     print "grb.keys():"
>>     print grb.keys()
>>     for key in grb.keys():
>>         print "\nKey: " + key
>>         print "data:"
>>         print grb[key]
>>     #print "grb['values']"
>>     #print grb['values']
>>     #print "grb['codedValues']"
>>     #print grb['codedValues']
>>     (pg_lats,pg_lons) = grb.latlons()
>>     pg_rows = pg_lats.shape[0]
>>     pg_cols = pg_lats.shape[1]
>>             #print test
>>             #print lats.shape, lats.min(), lats.max(), lons.shape,
>> lons.min(), lons.max()
>>             #lat_pygrib_arr = []
>>     print size(pg_lats)
>> print "\n\n"
>> ## open with gdal
>> ds = gdal.Open(filename)
>> band = ds.GetRasterBand(1)
>> data = band.ReadAsArray(0,0,band.XSize,band.YSize)#.flatten()
>> print "data:"
>> print data
>> The data values i get from pygrib are:
>> data:
>> [[ 294.5   294.5   294.5  ...,  298.31  298.32  298.32]
>>  [ 294.5   294.5   294.5  ...,  298.32  298.22  298.22]
>>  [ 294.4   294.4   294.4  ...,  298.22  298.22  298.22]
>>  [ 280.91  280.91  280.81 ...,  264.2   264.3   264.5 ]
>>  [ 280.81  280.81  280.81 ...,  263.5   263.7   263.9 ]
>>  [ 280.81  280.81  280.81 ...,  262.8   263.    263.3 ]]
>> The values i get from gdal are:
>> data:
>> [[  7.65999756   7.65999756   7.65999756 ..., -10.35001221 -10.15
>>    -9.85001221]
>>  [  7.65999756   7.65999756   7.65999756 ...,  -9.65        -9.45001831
>>    -9.2500061 ]
>>  [  7.76000366   7.76000366   7.65999756 ...,  -8.95001831  -8.85001221
>>    -8.65      ]
>>  [ 21.2499939   21.2499939   21.2499939  ...,  25.07000122  25.07000122
>>    25.07000122]
>>  [ 21.35        21.35        21.35       ...,  25.17000732  25.07000122
>>    25.07000122]
>>  [ 21.35        21.35        21.35       ...,  25.15999756  25.17000732
>>    25.17000732]]
>> Is there anything obvious that i am doing wrong?
>> thanks
>> matt
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
