[gdal-dev] gdalwarp not using DEM with RPC
Goo Creations goocreations at gmail.com
Fri May 6 04:12:26 EDT 2011
Hi all
I have a image with the necessary DEM and RPB file. When I use:
gdalwarp -to "RPC_DEM=/tmp/dem.dem" -to "METHOD=RPC" raw.tif ortho.tif
OR
gdalwarp -to "RPC_DEM=/tmp/dem.dem" -rpc raw.tif ortho.tif
But when I warp the image, I see no difference between ortho.tif that was
generated with the RPC_DEM option and the one generated without it.
The region has bunch of mountains, so you definitely should see major
changes when using a DEM file.
Am I warping the image correctly, or is there something else that goes wrong
here?
Christoph
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110506/a34f5a30/attachment.html
