[gdal-dev] LoadLayers (FGDB)
Paul Ramsey pramsey at cleverelephant.ca
Fri May 6 19:19:47 EDT 2011
Right now LoadLayers is really really over-determined, checking every
node in the database for every possible child type, and then checking
every child for every child type. Based on practice, is it incorrect
to assume that we can only see the following OGR-readable objects in
the database:
\Table
\Feature Class
\Feature Dataset\Feature Class
Where the Feature Dataset is not actually readable, but contains
Feature Classes that are. If I'm wrong, could someone create me a FGDB
with a different structure to play with?
Paul
