[gdal-dev] Polygon assembly has failed for feature FIDN
Gabriel Breahna gabriel.breahna at euro.ro
Sun May 8 08:28:34 EDT 2011
Hello,
I am receiving this error into the MS_ERRORFILE log file:
msDrawMap(): Image handling error. Failed to draw layer named 'danube'.
msOGRFileNextShape(): OGR error. IllegalArgumentException: Points of
LinearRing do not form a closed linestring
The command:
$ ogrinfo 3R7D0421.000 DEPARE
for the bad polyline is returning:
Warning 1: Polygon assembly has failed for feature
FIDN=1245675120,FIDS=1.Geometry may be missing or incomplete.
The FIDN=1245675120 shows like this:
OGRFeature(DEPARE):83
   RCID (Integer) = 13443
   PRIM (Integer) = 3
   GRUP (Integer) = 1
   OBJL (Integer) = 42
   RVER (Integer) = 1
   AGEN (Integer) = 16203
   FIDN (Integer) = 1245675120
   FIDS (Integer) = 1
   LNAM (String) = 3F4B4A3F7E700001
   LNAM_REFS (StringList) = (null)
   FFPT_RIND (IntegerList) = (null)
   DRVAL1 (Real) = 0
   DRVAL2 (Real) = 2.5
   QUASOU (String) = (null)
   SOUACC (Real) = (null)
   VERDAT (Integer) = (null)
   INFORM (String) = (null)
   NINFOM (String) = (null)
   NTXTDS (String) = (null)
   SCAMAX (Integer) = (null)
   SCAMIN (Integer) = (null)
   TXTDSC (String) = (null)
   RECDAT (String) = (null)
   RECIND (String) = (null)
   SORDAT (String) = (null)
   SORIND (String) = (null)
   POLYGON ((26.6322891 44.062348,26.6323082
44.059205599999999,26.634665900000002
44.059761999999999,26.644989599999999 44.062533600000002,26.6488985
44.063665200000003,26.6566464 44.066031700000003,26.665587899999998
44.069101199999999,26.6761321 44.0727319,26.6827697
44.075017000000003,26.6842215 44.075574199999998,26.687099499999999
44.076769499999997,26.6902504 44.078103599999999,26.69256
44.079112700000003,26.6937053 44.079583599999999,26.6950092
44.080067,26.6961838 44.080417699999998,26.697206
44.080685899999999,26.6984746 44.0809828,26.699531499999999
44.081166899999999,26.69979 44.081209999999999,26.699819999999999
44.081209999999999,26.70032 44.081290000000003,26.70035
44.081299999999999,26.700849999999999 44.08137,26.700880000000002
44.08137,26.70138 44.08144,26.701409999999999
44.08144,26.701910000000002 44.081510000000002,26.70195
44.081510000000002,26.702459999999999 44.081569999999999,26.70251
44.081580000000002,26.70304 44.081629999999997,26.703099999999999
44.08164,26.703659999999999 44.081679999999999,26.70372
44.081690000000002,26.704329999999999 44.08173,26.70439
44.08173,26.70506 44.081760000000003,26.70511
44.081760000000003,26.705850000000002 44.081780000000002,26.7059
44.081780000000002,26.70671 44.081789999999998,26.707699999999999
44.081789999999998,26.70868 44.081769999999999,26.70871
44.081769999999999,26.70974 44.08175,26.709769999999999
44.08175,26.71084 44.08171,26.71086 44.08171,26.711950000000002
44.081670000000003,26.71198 44.081659999999999,26.713059999999999
44.081609999999998,26.71309 44.081609999999998,26.71416
44.081539999999997,26.714189999999999
44.081539999999997,26.715209999999999 44.08146,26.71526
44.08146,26.716229999999999 44.08137,26.71629 44.08137,26.71725
44.08126,26.71733 44.081249999999997,26.718319999999999
44.081119999999999,26.718389999999999 44.081110000000002,26.71947
44.080939999999998,26.719529999999999
44.080930000000002,26.720739999999999 44.080710000000003,26.72079
44.0807,26.722180000000002 44.08043,26.72221 44.080419999999997,26.72382
44.080080000000002,26.723849999999999
44.080069999999999,26.725729999999999
44.079659999999997,26.725899999999999
44.079619999999998,26.728649999999998 44.07882,26.730879999999999
44.078189999999999,26.73265 44.0777,26.7332834
44.077530099999997,26.7359826 44.076783499999998,26.738722299999999
44.0761945,26.7412429 44.075684000000003,26.744366299999999
44.075527,26.7485307 44.075644699999998,26.752640299999999
44.075958900000003,26.755325299999999 44.076155200000002,26.7571343
44.076396699999997,26.757063299999999 44.0829995,26.756789999999999
44.082970000000003,26.75648 44.082949999999997,26.75581
44.082839999999997,26.75553 44.082799999999999,26.75522
44.082749999999997,26.755089999999999 44.082749999999997,26.75487
44.082700000000003,26.7546 44.082659999999997,26.75447
44.082659999999997,26.754370000000002
44.082610000000003,26.754239999999999 44.082610000000003,26.75413
44.08258,26.753990000000002 44.082599999999999,26.753799999999998
44.08258,26.75348 44.08256,26.753029999999999 44.08249,26.75259
44.08245,26.75217 44.082419999999999,26.75187 44.08238,26.75141
44.082329999999999,26.75095 44.08231,26.750489999999999
44.082259999999998,26.75016 44.082259999999998,26.749759999999998
44.082189999999997,26.749369999999999
44.082120000000003,26.749179999999999
44.082140000000003,26.748550000000002 44.082079999999998,26.74821
44.082039999999999,26.74781 44.081989999999998,26.74726
44.08193,26.746839999999999 44.08193,26.74653
44.081879999999998,26.746189999999999 44.081789999999998,26.74584
44.081740000000003,26.745450000000002 44.081699999999998,26.74521
44.08175,26.74493 44.081719999999997,26.74444
44.081670000000003,26.744199999999999 44.081600000000002,26.74409
44.081470000000003,26.743950000000002
44.081470000000003,26.743729999999999
44.081449999999997,26.743379999999998
44.081449999999997,26.743010000000002
44.081400000000002,26.742799999999999 44.081359999999997,26.74218
44.081290000000003,26.7419 44.08124,26.741489999999999
44.081209999999999,26.741230000000002 44.081159999999997,26.7407
44.081069999999997,26.74044 44.081009999999999,26.73987
44.0809,26.738880000000002 44.0807,26.73833 44.08061,26.73777
44.0805,26.737290000000002 44.08043,26.737089999999998
44.080379999999998,26.73664 44.080329999999996,26.73617
44.080260000000003,26.73553 44.080159999999999,26.73507
44.080089999999998,26.734269999999999 44.079979999999999,26.73387
44.079909999999998,26.73365 44.079880000000003,26.73327
44.07983,26.732839999999999 44.079770000000003,26.73246
44.079720000000002,26.73215 44.079700000000003,26.731940000000002
44.079700000000003,26.731909999999999 44.079720000000002,26.73186
44.07978,26.731809999999999 44.07985,26.73178
44.079979999999999,26.73178 44.080100000000002,26.731719999999999
44.08021,26.731619999999999 44.080660000000002,26.731539999999999
44.081049999999998,26.73148 44.08117,26.73148
44.081270000000004,26.73143 44.081400000000002,26.7313
44.082369999999997,26.731359999999999
44.082500000000003,26.731449999999999 44.08258,26.73149
44.082639999999998,26.731439999999999
44.082749999999997,26.731349999999999 44.082839999999997,26.7312
44.082799999999999,26.73115 44.082799999999999,26.731079999999999
44.08274,26.73103 44.082630000000002,26.73111
44.082509999999999,26.731190000000002
44.082459999999998,26.731259999999999 44.082349999999998,26.7313
44.08209,26.73133 44.081899999999997,26.7314 44.081490000000002,26.7314
44.081319999999998,26.73143 44.081229999999998,26.73141
44.081189999999999,26.73141 44.08115,26.73149
44.081020000000002,26.73161 44.080419999999997,26.731660000000002
44.08023,26.731729999999999 44.080109999999998,26.731729999999999
44.079949999999997,26.73177 44.079909999999998,26.73177
44.07987,26.731839999999998 44.079729999999998,26.731819999999999
44.079689999999999,26.731660000000002 44.079659999999997,26.73151
44.079639999999998,26.731259999999999
44.079619999999998,26.730869999999999
44.079619999999998,26.730419999999999
44.079630000000002,26.730139999999999 44.07965,26.729959999999998
44.079680000000003,26.72973 44.07974,26.729500000000002
44.07976,26.728999999999999 44.07974,26.728639999999999
44.07974,26.72833 44.079729999999998,26.7282 44.07976,26.728149999999999
44.079790000000003,26.7281 44.07987,26.72805 44.079970000000003,26.72791
44.080019999999998,26.72775 44.08005,26.727699999999999
44.080100000000002,26.72773 44.080150000000003,26.727900000000002
44.080280000000002,26.728000000000002 44.080350000000003,26.72814
44.080489999999998,26.728280000000002 44.080640000000002,26.72839
44.080730000000003,26.72849 44.08079,26.72858 44.08079,26.72868
44.080849999999998,26.728750000000002 44.0809,26.7288
44.080939999999998,26.72894 44.08106,26.729019999999998
44.081119999999999,26.72906 44.08117,26.72916
44.08124,26.729220000000002 44.081290000000003,26.729299999999999
44.08133,26.72935 44.08137,26.72934 44.081470000000003,26.72934
44.08153,26.729379999999999 44.081659999999999,26.72943
44.081850000000003,26.72946 44.081899999999997,26.72944
44.081940000000003,26.72944 44.081969999999998,26.729469999999999
44.082,26.72946 44.08202,26.729479999999999
44.082160000000002,26.729479999999999 44.082239999999999,26.72945
44.08227,26.72943 44.082320000000003,26.72944
44.082340000000002,26.72944 44.082369999999997,26.72943 44.0824,26.72941
44.082430000000002,26.729399999999998 44.08245,26.72941
44.08247,26.72941 44.08249,26.729399999999998
44.082509999999999,26.729399999999998
44.082540000000002,26.729389999999999 44.082590000000003,26.72934
44.082610000000003,26.72926 44.082610000000003,26.729179999999999
44.082569999999997,26.72915 44.08256,26.729109999999999
44.08256,26.72898 44.082549999999998,26.72895
44.082569999999997,26.728929999999998 44.082569999999997,26.72888
44.082549999999998,26.72886 44.082529999999998,26.72885
44.082509999999999,26.728819999999999 44.082479999999997,26.72876
44.082459999999998,26.728719999999999 44.08245,26.72869
44.082439999999998,26.72868 44.082389999999997,26.72868
44.082299999999996,26.72876 44.082189999999997,26.72876
44.082140000000003,26.72879 44.08209,26.728829999999999
44.08193,26.72879 44.081789999999998,26.72879
44.081690000000002,26.728840000000002
44.081650000000003,26.728809999999999 44.081600000000002,26.72885
44.081479999999999,26.7287 44.081310000000002,26.728649999999998
44.081209999999999,26.72852 44.081090000000003,26.7284
44.081020000000002,26.72833 44.080919999999999,26.72824
44.080800000000004,26.72814 44.080719999999999,26.727979999999999
44.0805,26.72782 44.080350000000003,26.727519999999998
44.080199999999998,26.72728 44.08012,26.72709 44.08005,26.72702
44.079949999999997,26.726839999999999 44.07976,26.726839999999999
44.079680000000003,26.72632 44.079790000000003,26.72632
44.079900000000002,26.726310000000002 44.080199999999998,26.72604
44.080419999999997,26.725639999999999
44.080640000000002,26.724519999999998
44.081009999999999,26.724299999999999
44.081090000000003,26.723939999999999 44.081180000000003,26.72363
44.081220000000002,26.72354 44.08133,26.72335
44.081449999999997,26.72304 44.081600000000002,26.72296
44.081560000000003,26.72278 44.081589999999998,26.722650000000002
44.081629999999997,26.722329999999999 44.08173,26.72212
44.08182,26.72194 44.081859999999999,26.72174
44.081859999999999,26.721589999999999
44.081969999999998,26.721419999999998 44.082,26.72125 44.082,26.72087
44.082070000000002,26.720490000000002
44.082099999999997,26.720009999999998 44.082140000000003,26.71988
44.08218,26.719439999999999 44.082239999999999,26.718979999999998
44.08229,26.718769999999999 44.08229,26.71819
44.082320000000003,26.717849999999999
44.082279999999997,26.717659999999999 44.082279999999997,26.71741
44.082340000000002,26.717169999999999 44.08238,26.71696
44.08238,26.71677 44.082419999999999,26.716059999999999
44.082419999999999,26.715959999999999 44.08249,26.715779999999999
44.082520000000002,26.71524 44.082520000000002,26.71517
44.08247,26.715019999999999 44.08247,26.7146 44.082509999999999,26.71404
44.082509999999999,26.713809999999999 44.082459999999998,26.71283
44.082459999999998,26.712289999999999 44.082419999999999,26.71197
44.082419999999999,26.711729999999999
44.082389999999997,26.711459999999999
44.082340000000002,26.711169999999999 44.082340000000002,26.71103
44.0824,26.71076 44.082349999999998,26.71055 44.08229,26.710419999999999
44.082340000000002,26.71029 44.082299999999996,26.70989
44.082239999999999,26.70896 44.082239999999999,26.708760000000002
44.082259999999998,26.70853 44.082210000000003,26.70832
44.082210000000003,26.70813 44.082160000000002,26.70796
44.082140000000003,26.70775 44.082160000000002,26.70719
44.082160000000002,26.70693 44.08211,26.70663
44.082140000000003,26.70643 44.082189999999997,26.70617
44.082149999999999,26.70587 44.082079999999998,26.70511
44.082079999999998,26.704899999999999
44.082050000000002,26.704719999999998 44.08209,26.70454
44.08209,26.703939999999999 44.082070000000002,26.70365
44.082039999999999,26.70334 44.081969999999998,26.703029999999998
44.081949999999999,26.70267 44.081899999999997,26.702079999999999
44.081789999999998,26.701799999999999 44.08173,26.70156
44.081629999999997,26.701339999999998
44.081629999999997,26.700939999999999 44.081560000000003,26.70065
44.081490000000002,26.70045 44.081490000000002,26.700220000000002
44.081519999999998,26.700009999999999 44.081490000000002,26.69968
44.08146,26.699359999999999 44.081400000000002,26.698979999999999
44.081400000000002,26.698810000000002
44.081359999999997,26.698619999999998 44.08124,26.698409999999999
44.08124,26.698139999999999 44.08117,26.69791
44.081099999999999,26.69769 44.081099999999999,26.69733
44.081009999999999,26.696739999999998 44.0809,26.696539999999999
44.080840000000002,26.6964 44.080800000000004,26.696280000000002
44.080779999999997,26.69602 44.080719999999999,26.695689999999999
44.080660000000002,26.695499999999999
44.080640000000002,26.695409999999999
44.080570000000002,26.695029999999999 44.080440000000003,26.69481
44.080379999999998,26.69463 44.080280000000002,26.69455
44.080249999999999,26.69436 44.080170000000003,26.693709999999999
44.07994,26.693079999999998 44.079689999999999,26.69291
44.079659999999997,26.692519999999998 44.079520000000002,26.69225
44.0794,26.691849999999999 44.079259999999998,26.691389999999998
44.079059999999998,26.69124 44.079030000000003,26.69106
44.07893,26.69078 44.07882,26.690629999999999
44.078769999999999,26.690339999999999
44.078719999999997,26.689959999999999 44.078629999999997,26.68975
44.078589999999998,26.68946 44.07853,26.68917
44.078409999999998,26.68869 44.078229999999998,26.68814
44.078000000000003,26.68786 44.07788,26.687449999999998
44.077759999999998,26.686889999999998 44.07757,26.68654
44.07748,26.685939999999999 44.0773,26.68561 44.077150000000003,26.68521
44.077060000000003,26.68505 44.07703,26.68468
44.076909999999998,26.684528499999999 44.076880699999997,26.6845053
44.076874199999999,26.6844596 44.076866699999997,26.68418
44.076819999999998,26.68373 44.076729999999998,26.68335
44.07667,26.68326 44.076630000000002,26.682919999999999 44.07654,26.6826
44.076509999999999,26.68242 44.076459999999997,26.682179999999999
44.076459999999997,26.681909999999998 44.076419999999999,26.68119
44.076250000000002,26.680759999999999 44.076120000000003,26.68028
44.075949999999999,26.679760000000002 44.075760000000002,26.67912
44.075499999999998,26.67874 44.075290000000003,26.678429999999999
44.075180000000003,26.67828 44.075159999999997,26.67802
44.075159999999997,26.677669999999999 44.07506,26.67719
44.074919999999999,26.676539999999999
44.074689999999997,26.676189999999998
44.074599999999997,26.675879999999999 44.0745,26.67564 44.07439,26.67521
44.074249999999999,26.674659999999999 44.07403,26.674669999999999
44.07403,26.674569999999999 44.073999999999998,26.674299999999999
44.073929999999997,26.674109999999999 44.073880000000003,26.67378
44.073810000000002,26.673559999999998
44.073749999999997,26.673369999999998 44.073709999999998,26.67304
44.073619999999998,26.67286 44.073569999999997,26.67267
44.07354,26.67231 44.073439999999998,26.67217
44.073410000000003,26.672039999999999 44.07336,26.67171
44.073239999999998,26.67163 44.073210000000003,26.67145
44.073140000000002,26.671279999999999 44.07307,26.670919999999999
44.072929999999999,26.6708 44.07289,26.670639999999999
44.07282,26.670529999999999 44.072769999999998,26.670249999999999
44.072659999999999,26.670179999999998 44.072609999999997,26.67005
44.072560000000003,26.669809999999998 44.07246,26.66973
44.072409999999998,26.66957 44.072339999999997,26.66937
44.07226,26.669239999999999 44.072189999999999,26.669
44.072119999999998,26.668849999999999 44.072090000000003,26.66872
44.072029999999998,26.668379999999999 44.071919999999999,26.66823
44.07186,26.66799 44.071779999999997,26.66759
44.071599999999997,26.667369999999998 44.07152,26.66714
44.071420000000003,26.66703 44.07139,26.666530000000002
44.07119,26.666329999999999 44.071089999999998,26.66621
44.071019999999997,26.666119999999999 44.070950000000003,26.66589
44.070860000000003,26.6657 44.070779999999999,26.665559999999999
44.07074,26.66535 44.07065,26.66517 44.070569999999996,26.66489
44.070439999999998,26.6647 44.070369999999997,26.664619999999999
44.07029,26.66457 44.070259999999998,26.66449
44.070239999999998,26.66442 44.07025,26.66438 44.070210000000003,26.6644
44.07018,26.664429999999999 44.07016,26.66447
44.070140000000002,26.66447 44.070120000000003,26.664439999999999
44.070099999999996,26.664349999999999 44.07011,26.66419 44.07007,26.664
44.06998,26.66376 44.069879999999998,26.66365
44.069839999999999,26.663589999999999
44.069749999999999,26.663530000000002
44.069699999999997,26.663409999999999
44.069699999999997,26.663329999999998 44.069670000000002,26.6631937
44.069631,26.6631895 44.069629999999997,26.6631839
44.0696273,26.663049999999998 44.069569999999999,26.66289
44.069490000000002,26.66278 44.06944,26.662559999999999
44.069369999999999,26.662389999999998 44.06935,26.662269999999999
44.069319999999998,26.662179999999999
44.069279999999999,26.662124899999998
44.069279999999999,26.662120000000002 44.069279999999999,26.66205
44.069339999999997,26.661989999999999 44.06944,26.66189
44.069479999999999,26.66166 44.06953,26.661359999999998
44.069609999999997,26.66114 44.069679999999998,26.66095
44.069760000000002,26.66076 44.069809999999997,26.66066
44.069850000000002,26.660620000000002 44.06991,26.66053
44.07,26.660430000000002 44.07002,26.660329999999998
44.069949999999999,26.65999 44.070030000000003,26.659579999999998
44.07016,26.659369999999999 44.0702,26.65922 44.07027,26.659109999999998
44.070329999999998,26.657109999999999 44.069780000000002,26.65781
44.068460000000002,26.657990000000002 44.068109999999997,26.65821
44.068159999999999,26.658519999999999
44.068249999999999,26.658609999999999 44.0683,26.65903
44.068420000000003,26.65932 44.0685,26.659579999999998
44.068629999999999,26.65973 44.068689999999997,26.65997
44.06877,26.66018 44.068809999999999,26.660419999999998
44.068849999999998,26.66064 44.06888,26.660779999999999
44.068930000000002,26.660969999999999 44.06895,26.66119
44.069000000000003,26.661339999999999
44.069070000000004,26.661449999999999 44.069119999999998,26.66157
44.069200000000002,26.66168 44.069229999999997,26.66187
44.06926,26.661999999999999 44.06926,26.66206
44.069249999999997,26.662073299999999
44.069236600000004,26.662109999999998 44.069200000000002,26.66213
44.069099999999999,26.662179999999999 44.069029999999998,26.66216
44.069000000000003,26.66178 44.068910000000002,26.661460000000002
44.068820000000002,26.661149999999999 44.068710000000003,26.66085
44.068559999999998,26.66047 44.068420000000003,26.660209999999999
44.068289999999998,26.66001 44.068129999999996,26.65988
44.06801,26.659680000000002 44.06794,26.659559999999999
44.067909999999998,26.659369999999999 44.067860000000003,26.65922
44.067790000000002,26.65915 44.067749999999997,26.659089999999999
44.067709999999998,26.65904 44.06774,26.65851
44.067509999999999,26.658529999999999 44.067480000000003,26.65851
44.067480000000003,26.6584 44.067430000000002,26.658259999999999
44.06736,26.65809 44.06729,26.6579 44.067219999999999,26.65783
44.067140000000002,26.657800000000002 44.067100000000003,26.6577436
44.067067899999998,26.6577199 44.0671004,26.6568787 44.0668608,26.656897
44.066820300000003,26.65688 44.06682,26.65673
44.066859999999998,26.65659 44.066870000000002,26.656469999999999
44.066839999999999,26.65631 44.066769999999998,26.656079999999999
44.06669,26.65586 44.066609999999997,26.655629999999999
44.066519999999997,26.65548 44.066459999999999,26.65528
44.066369999999999,26.65504 44.066270000000003,26.654769999999999
44.066249999999997,26.65464 44.06622,26.65437
44.066119999999998,26.65416 44.066049999999997,26.6539
44.065989999999999,26.65382 44.06597,26.65341
44.065869999999997,26.652719999999999 44.065669999999997,26.65247
44.06559,26.65237 44.065559999999998,26.65232
44.06561,26.652080000000002 44.065539999999999,26.6519
44.06548,26.651579999999999 44.065420000000003,26.651399999999999
44.065350000000002,26.6510801 44.065262699999998,26.65107
44.065260000000002,26.650950900000002
44.065218199999997,26.650649999999999 44.065109999999997,26.65051
44.065080000000002,26.65031 44.065060000000003,26.650110000000002
44.065060000000003,26.64994 44.06503,26.649709999999999
44.064970000000002,26.64947 44.064889999999998,26.649159999999998
44.064819999999997,26.64894 44.064779999999999,26.64862
44.064700000000002,26.64828 44.064599999999999,26.64798
44.06447,26.64786 44.064430000000002,26.64772
44.06438,26.647629999999999 44.064329999999998,26.647559999999999
44.06427,26.64731 44.064210000000003,26.64713
44.064169999999997,26.646999999999998
44.064120000000003,26.646889999999999 44.064109999999999,26.6465584
44.064033899999998,26.646409999999999 44.064,26.646149999999999
44.063920000000003,26.64592 44.063859999999998,26.645510000000002
44.063749999999999,26.645289999999999 44.063699999999997,26.64509
44.063639999999999,26.64496 44.063589999999998,26.64488
44.063569999999999,26.644839999999999
44.063580000000002,26.644739999999999
44.063580000000002,26.644599800000002 44.0635659,26.644582199999999
44.063564200000002,26.644439999999999 44.063549999999999,26.644165
44.063504999999999),(26.6322891 44.062348,26.632359999999998
44.062379999999997,26.63251 44.062429999999999,26.63305
44.062429999999999,26.63314 44.062489999999997,26.633189999999999
44.062550000000002,26.63341 44.062609999999999,26.63361
44.062640000000002,26.633949999999999 44.06268,26.634119999999999
44.062669999999997,26.634239999999998 44.062669999999997,26.63435
44.0627,26.63455 44.0627,26.634609999999999 44.06275,26.63476
44.062779999999997,26.634889999999999 44.062800000000003,26.6351
44.062829999999998,26.63532 44.06288,26.635560000000002
44.062910000000002,26.635750000000002 44.062939999999998,26.63586
44.062939999999998,26.635999999999999 44.062899999999999,26.63616
44.062869999999997,26.63655 44.062899999999999,26.63671
44.06293,26.63681 44.062989999999999,26.636939999999999
44.063029999999998,26.637219999999999
44.063079999999999,26.637519999999999 44.063099999999999,26.63766
44.063139999999997,26.63786 44.063139999999997,26.63793
44.063119999999998,26.63812 44.06315,26.638359999999999
44.063180000000003,26.638719999999999
44.063270000000003,26.638999999999999
44.063293199999997,26.639199999999999 44.06331,26.63954
44.06333,26.639959999999999 44.06335,26.640319999999999
44.06335,26.64048 44.063339999999997,26.640910000000002
44.063339999999997,26.64105 44.063319999999997,26.6414
44.063319999999997,26.641719999999999
44.063310299999998,26.641750699999999 44.063309500000003,26.64207
44.063299999999998,26.642659999999999
44.063299999999998,26.643049999999999 44.06333,26.64329
44.063369999999999,26.6435424 44.063403100000002),(26.755099999999999
44.080750000000002,26.75506 44.080759999999998,26.755019999999998
44.080779999999997,26.75497 44.080800000000004,26.754899999999999
44.080820000000003,26.754709999999999 44.080820000000003,26.75461
44.08081,26.754539999999999 44.08079,26.754460000000002
44.080759999999998,26.754349999999999 44.080730000000003,26.7543
44.080719999999999,26.754249999999999 44.080660000000002,26.7542
44.08059,26.754169999999998 44.080509999999997,26.7542 44.08043,26.75423
44.080379999999998,26.75428 44.080309999999997,26.75431
44.080280000000002,26.754370000000002
44.080240000000003,26.754439999999999 44.080199999999998,26.7545
44.080190000000002,26.75456 44.080159999999999,26.7546
44.080170000000003,26.754650000000002 44.080199999999998,26.75469
44.08023,26.75477 44.080269999999999,26.75485
44.080280000000002,26.75494 44.080280000000002,26.75503
44.080269999999999,26.755099999999999 44.080219999999997,26.75513
44.08021,26.755199999999999 44.080179999999999,26.75533
44.080159999999999,26.75542 44.080159999999999,26.755490000000002
44.080129999999997,26.755579999999998 44.080100000000002,26.75563
44.080080000000002,26.7557 44.080089999999998,26.75579 44.08012,26.75583
44.080150000000003,26.755870000000002
44.080190000000002,26.756029999999999 44.080280000000002,26.7561
44.080329999999996,26.756150000000002 44.08039,26.756139999999998
44.080460000000002,26.756129999999999 44.08048,26.75608 44.0805,26.75601
44.080509999999997,26.755960000000002
44.080530000000003,26.755939999999999
44.080550000000002,26.755960000000002
44.080579999999998,26.756039999999999 44.08061,26.75625
44.080660000000002,26.756319999999999
44.080689999999997,26.756399999999999 44.080719999999999,26.75646
44.080730000000003,26.756589999999999
44.080759999999998,26.756620000000002 44.08077,26.75666
44.080800000000004,26.75667 44.080849999999998,26.75667
44.08088,26.75676 44.08097,26.75674 44.08099,26.756679999999999
44.081009999999999,26.75611 44.081009999999999,26.75607
44.081000000000003,26.755960000000002
44.080979999999997,26.755849999999999 44.08097,26.7558
44.080959999999997,26.755749999999999
44.080930000000002,26.755649999999999 44.08086,26.755569999999999
44.080840000000002,26.755490000000002 44.080829999999999,26.75542
44.080820000000003,26.75531 44.08081,26.75524
44.080779999999997,26.75515 44.080759999999998,26.755099999999999
44.080750000000002))
With the same file OpenCPN is working/rendering fine.
Any idea how to do in order to be able to show this layer?
Regards,
Gabriel
