[gdal-dev] Setting "INIT_DEST" to nan on windows
Kyle Shannon ksshannon at gmail.com
Mon May 9 19:08:41 EDT 2011
I did have to set the padfNoDataImag array as well, so I am one step
closer.  My new issue is ownership of my psWarpOptions.  I assume that since
I create it, and the warp api tutorial implies that is it mine, I destroy it
with GDALDestroyWarpOptions().  My problem is that AutoCreateWarpedVRT
appears to be stepping on my warp options when it destroys it's own copy.
I call AutoCreateWarpedVRT() and that function calls
GDALCloneWarpOptions().  When AutoCreateWarpedVRT destroys the copy it owns,
it appears to be stepping on my copy, and when I call
GDALDestroyWarpOptions(), I get a seg fault.  Am I doing something wrong?
kss
 * Kyle Shannon
 * ksshannon at gmail.com
On Mon, May 9, 2011 at 15:43, Even Rouault <even.rouault at mines-paris.org>wrote:
> Le lundi 09 mai 2011 23:30:05, Kyle Shannon a écrit :
> > Thanks Even,
> > If that is the case, are there other values in psWarpOptions I *have* to
> > set?  I can't find docs discussing that.
> I don't think so, but you'll just have to try... I'm not  surprised the
> docs
> don't talk about NaN. It is a corner case, and likely not really well
> supported in all places.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110509/46ede3c5/attachment.html
