[gdal-dev] Segmentation fault with debian install of gdal on MODIS hdf4 files
Jonathan Greenberg greenberg at ucdavis.edu
Mon May 9 20:56:22 EDT 2011
Folks:
I did a Debian install of both the "unstable" and the "experimental"
versions of GDAL, and when running gdal_translate on a MODIS HDF4 file
I'm getting a segmentation fault.  gdalinfo works fine tho.  Thoughts?
$ gdal_translate -ot Float32 -of ENVI
HDF4_EOS:EOS_GRID:MCD15A2.A2002185.h35v10.005.2007177210333.hdf:MOD_Grid_MOD15A2:Lai_1km
test_hdf.envi
Input file size is 1200, 1200
0Segmentation fault
$ gdalinfo HDF4_EOS:EOS_GRID:MCD15A2.A2002185.h35v10.005.2007177210333.hdf:MOD_Grid_MOD15A2:Lai_1km
Driver: HDF4Image/HDF4 Dataset
Files: MCD15A2.A2002185.h35v10.005.2007177210333.hdf
Size is 1200, 1200
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["Unknown datum based upon the custom spheroid",
        DATUM["Not specified (based on custom spheroid)",
            SPHEROID["Custom spheroid",6371007.181,0]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Sinusoidal"],
    PARAMETER["longitude_of_center",0],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["Meter",1]]
Origin = (18903158.834332998842001,-1111950.519667000044137)
Pixel Size = (926.625433055833014,-926.625433054999803)
Metadata:
  HDFEOSVersion=HDFEOS_V2.9
  LOCALGRANULEID=MCD15A2.A2002185.h35v10.005.2007177210333.hdf
  PRODUCTIONDATETIME=2007-06-26T21:03:33.000Z
  DAYNIGHTFLAG=Day
  REPROCESSINGACTUAL=reprocessed
  LOCALVERSIONID=5.0.4
  REPROCESSINGPLANNED=further update is anticipated
  SCIENCEQUALITYFLAG=Not Investigated
  AUTOMATICQUALITYFLAGEXPLANATION=No automatic quality assessment is
performed in the PGE
  AUTOMATICQUALITYFLAG=Passed
  SCIENCEQUALITYFLAGEXPLANATION=See
http://landweb.nascom/nasa.gov/cgi-bin/QA_WWW/qaFlagPage.cgi?sat=aqua
the product Science Quality status.
  QAPERCENTMISSINGDATA=99
  QAPERCENTOUTOFBOUNDSDATA=99
  QAPERCENTCLOUDCOVER=0
  QAPERCENTINTERPOLATEDDATA=0
  PARAMETERNAME=MCD15A2
  VERSIONID=5
  SHORTNAME=MCD15A2
  INPUTPOINTER=MYD15A1.A2002192.h35v10.005.2007162232536.hdf,
MYD15A1.A2002191.h35v10.005.2007162024118.hdf,
MYD15A1.A2002190.h35v10.005.2007162092900.hdf,
MYD15A1.A2002189.h35v10.005.2007161211830.hdf,
MYD15A1.A2002188.h35v10.005.2007161122622.hdf,
MYD15A1.A2002187.h35v10.005.2007161050931.hdf,
MYD15A1.A2002186.h35v10.005.2007161012141.hdf,
MYD15A1.A2002185.h35v10.005.2007161153557.hdf,
MOD15A1.A2002192.h35v10.005.2007163022444.hdf,
MOD15A1.A2002191.h35v10.005.2007162214105.hdf,
MOD15A1.A2002190.h35v10.005.2007162180320.hdf,
MOD15A1.A2002189.h35v10.005.2007161200152.hdf,
MOD15A1.A2002188.h35v10.005.2007161164154.hdf,
MOD15A1.A2002187.h35v10.005.2007160174423.hdf,
MOD15A1.A2002186.h35v10.005.2007152183046.hdf,
MOD15A1.A2002185.h35v10.005.2007152031253.hdf, MCD15A2_ANC_RI4.hdf
  GRINGPOINTLONGITUDE=172.479315908761, 172.622770159185,
179.999502554976, -179.856407114504
  GRINGPOINTLATITUDE=-19.1662177463598, -9.98364248250805,
-9.97534112170732, -19.180676222654
  GRINGPOINTSEQUENCENO=1, 2, 3, 4
  EXCLUSIONGRINGFLAG=N
  RANGEENDINGDATE=2002-07-11
  RANGEENDINGTIME=23:59:59
  RANGEBEGINNINGDATE=2002-07-04
  RANGEBEGINNINGTIME=00:00:00
  PGEVERSION=5.0.6
  ASSOCIATEDSENSORSHORTNAME=MODIS
  ASSOCIATEDPLATFORMSHORTNAME=Terra
  ASSOCIATEDINSTRUMENTSHORTNAME=MODIS
  ASSOCIATEDPLATFORMSHORTNAME=Aqua
  QAPERCENTGOODQUALITY=89
  QAPERCENTOTHERQUALITY=100
  HORIZONTALTILENUMBER=35
  VERTICALTILENUMBER=10
  TileID=51035010
  NDAYS_COMPOSITED=16
  QAPERCENTGOODFPAR=89
  QAPERCENTGOODLAI=89
  QAPERCENTMAINMETHOD=89
  QAPERCENTEMPIRICALMODEL=11
  NORTHBOUNDINGCOORDINATE=-9.99999999910197
  SOUTHBOUNDINGCOORDINATE=-19.1833333316106
  EASTBOUNDINGCOORDINATE=179.999999983337
  WESTBOUNDINGCOORDINATE=172.622524004598
  ALGORITHMPACKAGEACCEPTANCEDATE=10-01-2004
  ALGORITHMPACKAGEMATURITYCODE=Normal
  ALGORITHMPACKAGENAME=MCDPR_15A2
  ALGORITHMPACKAGEVERSION=5
  GEOANYABNORMAL=False
  GEOESTMAXRMSERROR=50.0
  LONGNAME=MODIS/Terra+Aqua Leaf Area Index/FPAR 8-Day L4 Global 1km SIN Grid
  PROCESSINGCENTER=MODAPS
  SYSTEMFILENAME=MYD15A1.A2002192.h35v10.005.2007162232536.hdf,
  NUMBEROFGRANULES=1
  GRANULEDAYNIGHTFLAG=Day
  GRANULEBEGINNINGDATETIME=2007-06-01T03:12:53.000Z
  GRANULEENDINGDATETIME=2007-06-01T03:12:53.000Z
  CHARACTERISTICBINANGULARSIZE=30.0
  CHARACTERISTICBINSIZE=926.625433055556
  DATACOLUMNS=1200
  DATAROWS=1200
  GLOBALGRIDCOLUMNS=43200
  GLOBALGRIDROWS=21600
  NADIRDATARESOLUTION=1km
  MAXIMUMOBSERVATIONS=1
  SPSOPARAMETERS=5367, 2680
  PROCESSINGENVIRONMENT=IRIX64 mtvs3 6.5 10070055 IP35
  DESCRREVISION=5.0
  ENGINEERING_DATA=
# MOD_PR15A2 (Vers 5.0.4 Rele 10.18.2006 23:59)
# MUM API Vers 2.5.8 Rev 104 Rel. 11.15.2000 10:49 (pgs)
# (c) 2000 J.M. Glassy, NTSG,LLSD
# portions of MUM API by Petr Votava,NTSG Lab,U.Montana
# HOST ECS_PGS_VirtualHost PROCESS 19540618
# PLATFORM Sys genericunix Vers unknown Release unknown Node (no
nodename available)
# INIT-TIME Tue Jun 26 17:00:14 2007
YEARDAY 185 COMPOSITE_PERIOD  24 FIRSTDAY_IN_PERIOD 185
SDS[PGE34_ISG_MBRLUT] ID 268697600 Rank   2 (664 120)
SDS[PGE34_OUTFIELD_PROP] ID 268697601 Rank   2 (78 179)
SDS[PGE34_BROWSEFIELD_PROP] ID 268697602 Rank   2 (77 164)
READANC SDS[PGE34_ISG_MBRLUT] RANK 2 (664 120)
READANC SDS[PGE34_OUTFIELD_PROP] RANK 2 (78 179)
READANC SDS[PGE34_BROWSEFIELD_PROP] RANK 2 (77 164)
READANC SDS[PGE34_ECSMETA_DICT] RANK 2 (73 110)
READANC SDS[PGE34_RELEASE_NOTES] RANK 2 (84 98)
FLDPROP SDSnam(PGE34_OUTFIELD_PROP)MoleName(PGE34_OUTFIELD_PROP)Status
3 Nelem 13962
BROWSE cvlBrwMol 0 Nelem 57600 Type 21 Status 3
BROWSE cvlBrwMol 1 Nelem 57600 Type 21 Status 3
BROWSE cvlBrwMol 2 Nelem 57600 Type 21 Status 3
BROWSE cvlBrwMol 3 Nelem 57600 Type 21 Status 3
BROWSE: NEW GRID ID 4194320
BROWSEFIELD  0 Sum 14571961 Average 252.985
BROWSEFIELD  1 Sum 14560181 Average 252.781
BROWSEFIELD  2 Sum 8999599 Average 156.243
BROWSEFIELD  3 Sum 14616929 Average 253.766
BROWSE-DONE: N-Pixels 57600 Invalid offsets: 0 OutOfRange 0
COMPOSITING FPAR FREQUENCIES
FPAR   6       33
FPAR   7       20
FPAR   8       11
FPAR   9        7
FPAR  10       18
FPAR  11        3
FPAR  12        7
FPAR  13       14
FPAR  14        9
FPAR  15       21
FPAR  16       15
FPAR  17        4
FPAR  18       10
FPAR  19       50
FPAR  20       24
FPAR  21       11
FPAR  22       13
FPAR  23        7
FPAR  24       26
FPAR  25       23
FPAR  26       22
FPAR  27       37
FPAR  28       26
FPAR  29       21
FPAR  30       33
FPAR  31       17
FPAR  32       33
FPAR  33       23
FPAR  34       17
FPAR  35       27
FPAR  36       22
FPAR  37       17
FPAR  38       35
FPAR  39       18
FPAR  40       35
FPAR  41       30
FPAR  42       25
FPAR  43       17
FPAR  44       38
FPAR  45       22
FPAR  46       27
FPAR  47       37
FPAR  48       45
FPAR  49       21
FPAR  50       29
FPAR  51       39
FPAR  52       37
FPAR  53       38
FPAR  54       33
FPAR  55       40
FPAR  56       26
FPAR  57       27
FPAR  58       40
FPAR  59       54
FPAR  60       54
FPAR  61       55
FPAR  62       51
FPAR  63       27
FPAR  64       66
FPAR  65       66
FPAR  66       66
FPAR  67       56
FPAR  68       57
FPAR  69       78
FPAR  70       67
FPAR  71       65
FPAR  72       69
FPAR  73       82
FPAR  74       75
FPAR  75       79
FPAR  76      101
FPAR  77       52
FPAR  78       68
FPAR  79       78
FPAR  80       73
FPAR  81       57
FPAR  82       62
FPAR  83       97
FPAR  84      137
FPAR  85      213
FPAR  86      170
FPAR  87      243
FPAR  88      410
FPAR  89     1142
FPAR  90     2373
FPAR  91      758
FPAR  92       68
FPAR  93      125
FPAR  94      179
FPAR  95      187
FPAR  96      126
FPAR  97       31
FPAR  98       13
FPAR  99        4
COMPOSITING LAI FREQUENCIES
LAI    1       68
LAI    2       53
LAI    3      131
LAI    4       56
LAI    5      109
LAI    6      114
LAI    7      112
LAI    8       85
LAI    9       96
LAI   10       98
LAI   11      107
LAI   12       75
LAI   13       80
LAI   14      104
LAI   15       93
LAI   16      135
LAI   17       71
LAI   18       95
LAI   19       97
LAI   20      103
LAI   21      106
LAI   22       90
LAI   23       95
LAI   24      122
LAI   25       94
LAI   26       66
LAI   27       68
LAI   28       71
LAI   29       39
LAI   30       53
LAI   31       38
LAI   32       35
LAI   33       48
LAI   34       50
LAI   35       40
LAI   36       46
LAI   37       44
LAI   38       59
LAI   39       79
LAI   40       76
LAI   41       99
LAI   42       66
LAI   43       64
LAI   44       50
LAI   45       50
LAI   46       71
LAI   47       50
LAI   48       73
LAI   49      130
LAI   50       89
LAI   51      115
LAI   52       79
LAI   53      116
LAI   54      160
LAI   55      191
LAI   56      339
LAI   57      390
LAI   58      272
LAI   59      263
LAI   60     1178
LAI   61      225
LAI   62      211
LAI   63      273
LAI   64      358
LAI   65      142
LAI   66      107
LAI   67      449
LAI   68       57
LAI   69      246
COMPOSITING DAY INDEX FREQUENCIES
TILE-INDEX    0 Selection Frequency:      205
TILE-INDEX    1 Selection Frequency:     1166
TILE-INDEX    2 Selection Frequency:      732
TILE-INDEX    3 Selection Frequency:     1987
TILE-INDEX    4 Selection Frequency:      524
TILE-INDEX    5 Selection Frequency:      886
TILE-INDEX    6 Selection Frequency:       29
TILE-INDEX    7 Selection Frequency:      566
TILE-INDEX    8 Selection Frequency:      469
TILE-INDEX    9 Selection Frequency:      740
TILE-INDEX   10 Selection Frequency:     1224
TILE-INDEX   11 Selection Frequency:      343
TILE-INDEX   12 Selection Frequency:      146
TILE-INDEX   13 Selection Frequency:       97
TILE-INDEX   14 Selection Frequency:        0
TILE-INDEX   15 Selection Frequency:        0
LOCALGRANULEID [MCD15A2.A2002185.h35v10.005.2007177210333.hdf]
ECS QC PERCENT N valid (demominator) : 9114.000000
ECS Total Pixels       (denominator) : 1440000
QAPERCENTxx PSA BEFORE CALC
QAPERCENTINTERPOLATEDDATA: 0
QAPERCENTMISSINGDATA     : 1430886
QAPERCENTOUTOFBOUNDSDATA : 1430886
QAPERCENTCLOUDCOVER      : 487
QAPERCENTNOTPRODUCEDCLOUD: 0
QAPERCENTNOTPRODUCEDOTHER: 0
QAPERCENTGOODQUALITY     : 8135
QAPERCENTOTHERQUALITY    : 1431865
QAPERCENTGOODFPAR        : 8135
QAPERCENTGOODLAI         : 8135
QAPERCENTMAINMETHOD      : 8135
QAPERCENTEMPIRICALMODEL  : 979
QAPERCENTNDAYSCOMPOSITED : 16
QAPERCENTTERRA           : 5527
QAPERCENTxx PSA AFTER CALC
QAPERCENTMISSINGDATA     : 99
QAPERCENTOUTOFBOUNDSDATA : 99
QAPERCENTCLOUDCOVER      : 0
QAPERCENTGOODQUALITY     : 89
QAPERCENTOTHERQUALITY    : 100
QAPERCENTGOODFPAR        : 89
QAPERCENTGOODLAI         : 89
QAPERCENTMAINMETHOD      : 89
QAPERCENTEMPIRICALMODEL  : 11
SESSION ENGINEERING SUMMARY FOR PGE34 8-day FPAR,LAI
UM_VERSION U.MONTANA MODIS PGE34 Vers 5.0.4 Rev 4 Release 10.18.2006 23:59
Candidate Days: 16
N. invalid loads      : 0
Pixels failing best day : 1430886
Pixels set to fill      : 0
Pixels skipped (disqual): 22915542
Unclassified Pixels     : 1430886
MOD15A1 DAILY Input:
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002185.h35v10.005.2007152031253.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002186.h35v10.005.2007152183046.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002187.h35v10.005.2007160174423.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002188.h35v10.005.2007161164154.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002189.h35v10.005.2007161200152.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002190.h35v10.005.2007162180320.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002191.h35v10.005.2007162214105.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002192.h35v10.005.2007163022444.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002185.h35v10.005.2007161153557.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002186.h35v10.005.2007161012141.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002187.h35v10.005.2007161050931.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002188.h35v10.005.2007161122622.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002189.h35v10.005.2007161211830.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002190.h35v10.005.2007162092900.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002191.h35v10.005.2007162024118.hdf
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002192.h35v10.005.2007162232536.hdf
PGE34 Output       :
/MODAPSops3/archive/f46/running/AMPM_L10/16495460/MCD15A2.1.2002-185T00:00:00.000000Z.51035010.18515794.215230_1.hdf
MOD15A2 ANCILLARY    : /MODAPSops3/PGE/AMPM/coeff/PGE34/MCD15A2_ANC_RI4.hdf
QAPERCENTTERRA          : 61
Started Tue Jun 26 17:00:14 2007  Ended Tue Jun 26 17:03:33 2007
Elapsed Time         199 Sec (       3.32 Min)
  MOD15A2_FILLVALUE_DOC=MOD15A2 FILL VALUE LEGEND
255 = _Fillvalue, assigned when:
    * the MODAGAGG suf. reflectance for channel VIS, NIR was assigned
its _Fillvalue, or
    * land cover pixel itself was assigned _Fillvalus 255 or 254.
254 = land cover assigned as perennial salt or inland fresh water.
253 = land cover assigned as barren, sparse vegetation (rock, tundra, desert.)
252 = land cover assigned as perennial snow, ice.
251 = land cover assigned as "permanent" wetlands/inundated marshlands.
250 = land cover assigned as urban/built-up.
249 = land cover assigned as "unclassified" or not able to determine.
  MOD15A2_FparLai_QC_DOC=
FparLai_QC 5 BITFIELDS IN 8 BITWORD
MODLAND_QC START 0 END 0 VALIDS 2
MODLAND_QC   0 = Good Quality (main algorithm with or without saturation)
MODLAND_QC   1 = Other Quality (back-up algorithm or fill value)
SENSOR START 1 END 1 VALIDS 2
SENSOR       0  = Terra
SENSOR       1  = Aqua
DEADDETECTOR START 2 END 2 VALIDS 2
DEADDETECTOR 0 = Detectors apparently fine for up to 50% of channels 1,2
DEADDETECTOR 1 = Dead detectors caused >50% adjacent detector retrieval
CLOUDSTATE START 3 END 4 VALIDS 4 (this inherited from Aggregate_QC
bits {0,1} cloud state)
CLOUDSTATE   00 = 0 Significant clouds NOT present (clear)
CLOUDSTATE   01 = 1 Significant clouds WERE present
CLOUDSTATE   10 = 2 Mixed cloud present on pixel
CLOUDSTATE   11 = 3 Cloud state not defined,assumed clear
SCF_QC START 5 END 7 VALIDS 5
SCF_QC       000=0 Main (RT) algorithm used, best result possible (no
saturation)
SCF_QC       001=1 Main (RT) algorithm used, saturation occured. Good,
very usable.
SCF_QC       010=2 Main algorithm failed due to bad geometry,
empirical algorithm used
SCF_QC       011=3 Main algorithm faild due to problems other than
geometry, empirical algorithm used
SCF_QC       100=4 Pixel not produced at all, value coudn't be
retrieved (possible reasons: bad L1B data, unusable MODAGAGG data)
  MOD15A2_FparExtra_QC_DOC=
FparExtra_QC 6 BITFIELDS IN 8 BITWORD
LANDSEA PASS-THROUGH START 0 END 1 VALIDS 4
LANDSEA   00 = 0 LAND       AggrQC(3,5)values{001}
LANDSEA   01 = 1 SHORE      AggrQC(3,5)values{000,010,100}
LANDSEA   10 = 2 FRESHWATER AggrQC(3,5)values{011,101}
LANDSEA   11 = 3 OCEAN      AggrQC(3,5)values{110,111}
SNOW_ICE (from Aggregate_QC bits) START 2 END 2 VALIDS 2
SNOW_ICE  0 = No snow/ice detected
SNOW_ICE  1 = Snow/ice were detected
AEROSOL START 3 END 3 VALIDS 2
AEROSOL   0 = No or low atmospheric aerosol levels detected
AEROSOL   1 = Average or high aerosol levels detected
CIRRUS (from Aggregate_QC bits {8,9} ) START 4 END 4 VALIDS 2
CIRRUS    0 = No cirrus detected
CIRRUS    1 = Cirrus was detected
INTERNAL_CLOUD_MASK START 5 END 5 VALIDS 2
INTERNAL_CLOUD_MASK 0 = No clouds
INTERNAL_CLOUD_MASK 1 = Clouds were detected
CLOUD_SHADOW START 6 END 6 VALIDS 2
CLOUD_SHADOW        0 = No cloud shadow detected
CLOUD_SHADOW        1 = Cloud shadow detected
SCF_BIOME_MASK START 7 END 7 VALIDS 2
SCF_BIOME_MASK  0 = Biome outside interval <1,4>
SCF_BIOME_MASK  1 = Biome in interval <1,4>
  MOD15A2_StdDev_QC_DOC=MOD15A2 STANDARD DEVIATION FILL VALUE LEGEND
its _Fillvalue, or
248 = no standard deviation available, pixel produced using backup method.
  MOD15A1_ANC_BUILD_CERT=mtAncUtil v. 1.8 Rel. 09.11.2000 17:36 API v.
2.5.6 release 09.14.2000 16:33 Rev.Index 102 (J.Glassy)
  UM_VERSION=U.MONTANA MODIS PGE34 Vers 5.0.4 Rev 4 Release 10.18.2006 23:59
  scale_factor=0.1
  scale_factor_err=0
  add_offset=0
  add_offset_err=0
  calibrated_nt=21
  valid_range=0, 100
  _FillValue=255
  long_name=MCD15A2 MODIS/Terra+Aqua Gridded 1KM Leaf Area Index LAI
(8-day composite)
  units=m^2/m^2
its _Fillvalue, or
Corner Coordinates:
Upper Left  (18903158.834,-1111950.520) (172d37'21.09"E, 10d 0' 0.00"S)
Lower Left  (18903158.834,-2223901.039) (179d 5'23.20"W, 20d 0' 0.00"S)
Upper Right (20015109.354,-1111950.520) (177d13'23.56"W, 10d 0' 0.00"S)
Lower Right (20015109.354,-2223901.039) (168d26'52.80"W, 20d 0' 0.00"S)
Center      (19459134.094,-1667925.779) (178d49'36.01"W, 15d 0' 0.00"S)
Band 1 Block=1200x100 Type=Byte, ColorInterp=Gray
  Description = MCD15A2 MODIS/Terra+Aqua Gridded 1KM Leaf Area Index
LAI (8-day composite)
  NoData Value=255
  Unit Type: m^2/m^2
  Offset: 0,   Scale:0.1
Jonathan A. Greenberg, PhD
Assistant Project Scientist
Center for Spatial Technologies and Remote Sensing (CSTARS)
Department of Land, Air and Water Resources
University of California, Davis
One Shields Avenue
Davis, CA 95616
Phone: 415-763-5476
AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307
