[gdal-dev] Setting "INIT_DEST" to nan on windows
Kyle Shannon ksshannon at gmail.com
Tue May 10 11:39:52 EDT 2011
Even, here is the basic flow of my task.  I am opening several subdatasets
in a for loop, warping them and populating an internal data structure.
#include "gdal_priv.h"
#include "gdalwarper.h"
#include "cpl_conv.h"
#include "cpl_port.h"
#include <string>
#include <vector>
int main()
GDALAllRegister();
 * Variable names for the netcdf forecast file
std::vector<std::string> varList;
varList.push_back( "Temperature_height_above_ground" );
varList.push_back( "V-component_of_wind_height_above_ground" );
varList.push_back( "U-component_of_wind_height_above_ground" );
varList.push_back( "Total_cloud_cover" );
std::string temp;
GDALDataset* srcDS;
GDALDataset* wrpDS;
GDALWarpOptions* psWarpOptions;
std::string srcWkt, dstWkt;
dstWkt = "PROJCS[\"WGS 84 / UTM zone 12N\",GEOGCS[\"WGS
84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS
84\",6378137,298.257223563]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433]],UNIT[\"metre\",1],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"latitude_of_origin\",0],PARAMETER[\"central_meridian\",-111],PARAMETER[\"scale_factor\",0.9996],PARAMETER[\"false_easting\",500000],PARAMETER[\"false_northing\",0]]";
 * Loop over variable names and open sub datasets
for( int i = 0;i < varList.size();i++ ) {
    temp = "NETCDF:test.nc:" + varList[i];
    srcDS = (GDALDataset*)GDALOpenShared( temp.c_str(), GA_ReadOnly );
    srcWkt = srcDS->GetProjectionRef();
     * Grab the first band to get the nodata value for the variable,
     * assume all bands have the same ndv
    GDALRasterBand *poBand = srcDS->GetRasterBand( 1 );
    int pbSuccess;
    double dfNoData = poBand->GetNoDataValue( &pbSuccess );
    psWarpOptions = GDALCreateWarpOptions();
    int nBandCount = srcDS->GetRasterCount();
    psWarpOptions->padfDstNoDataReal =
        (double*) CPLMalloc( sizeof( double ) * nBandCount );
    psWarpOptions->padfDstNoDataImag =
    for( int b = 0;b < srcDS->GetRasterCount();b++ ) {
        psWarpOptions->padfDstNoDataReal[b] = dfNoData;
        psWarpOptions->padfDstNoDataImag[b] = dfNoData;
    if( pbSuccess == false )
        dfNoData = -9999.0;
    psWarpOptions->papszWarpOptions =
    CSLSetNameValue( psWarpOptions->papszWarpOptions,
                     "INIT_DEST", "NO_DATA" );
    //set the dskWkt with an internal structure
    wrpDS = (GDALDataset*) GDALAutoCreateWarpedVRT( srcDS, srcWkt.c_str(),
                                                    dstWkt.c_str(),
                                                    GRA_NearestNeighbour,
                                                    1.0, psWarpOptions );
    //copy warped data to internal structure
    GDALDestroyWarpOptions( psWarpOptions );
    GDALClose((GDALDatasetH) srcDS );
    GDALClose((GDALDatasetH) wrpDS );
I am sure I am missing something.
kss
 * Kyle Shannon
 * ksshannon at gmail.com
On Tue, May 10, 2011 at 03:51, Even Rouault <even.rouault at mines-paris.org>wrote:
> Selon Kyle Shannon <ksshannon at gmail.com>:
> > I did have to set the padfNoDataImag array as well, so I am one step
> > closer.  My new issue is ownership of my psWarpOptions.  I assume that
> since
> > I create it, and the warp api tutorial implies that is it mine, I destroy
> it
> > with GDALDestroyWarpOptions().  My problem is that AutoCreateWarpedVRT
> > appears to be stepping on my warp options when it destroys it's own copy.
> > I call AutoCreateWarpedVRT() and that function calls
> > GDALCloneWarpOptions().  When AutoCreateWarpedVRT destroys the copy it
> owns,
> > it appears to be stepping on my copy, and when I call
> > GDALDestroyWarpOptions(), I get a seg fault.  Am I doing something wrong?
> Difficult to say without seeing your code. Could you post a small
> self-sufficient code snippet that demonstrates your issue ?
> By reviewing the code, one potential issue would be if you try to free the
> pTransformerArg field by yourself, as it is freed by the destructor of the
> VRTWarpedDataset. But if you just use GDALDestroyWarpOptions(), it should
> work
> OK
> > kss
> >  * Kyle Shannon
> > On Mon, May 9, 2011 at 15:43, Even Rouault
> > > Le lundi 09 mai 2011 23:30:05, Kyle Shannon a écrit :
> > > > Thanks Even,
> > > > If that is the case, are there other values in psWarpOptions I *have*
> to
> > > > set?  I can't find docs discussing that.
> > > I don't think so, but you'll just have to try... I'm not  surprised the
> > > docs
> > > don't talk about NaN. It is a corner case, and likely not really well
> > > supported in all places.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110510/201c04cc/attachment.html
