[gdal-dev] Re: Datum Shifts with OSR.CoordinateTransform
srweal srweal at gmail.com
Tue May 10 19:47:16 EDT 2011
Armin,
Thanks for the reply. That seems like a logical approach, but can you or any
of the GDAL developers tell me whether these +TOWGS84 parameters are
applied/supported or not.
Also, I have seen some references to using a +NADGRID option for specifying
a transformation grid (rather than just the 7 parameters).
Are these parameters supported? And if so, can they be defined for the
CoordinateTransform as a whole without importing from WKT?
Thanks,
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Datum-Shifts-with-OSR-CoordinateTransform-tp6346391p6350115.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
