[gdal-dev] Re: VRT Derived Bands from Python?
Knut-Frode Dagestad knutfrodesoppel at hotmail.com
Fri May 13 13:27:23 EDT 2011
On 13/05/2011 19:07, Even Rouault wrote:
> I had also a similar error on Linux, but it worked despite the error. I have
> pushed a fix in trunk to silent that error. You can try to add a printf()
> statement in your GDALRegisterMe function to check if it is loaded correctly.
You are right, it works despite the error message!
I did not even think about checking that...
Great, thanks alot once again!
