[gdal-dev] GDAL build problems under Linux debian x86_64
Even Rouault even.rouault at mines-paris.org
Mon May 16 05:21:17 EDT 2011
Selon Josh.Vote at csiro.au:
I somehow had similar problems, that I solved by replacing the libtool file
coming with GDAL with the one of my system from /usr/bin.
I'm also wondering if the correction made in
http://trac.osgeo.org/gdal/ticket/3928 wouldn't fix the issue.
> Hi,
> I'm currently trying to build gdal trunk (rev 22377) on an amd64 Linux
> (Debian) box and I keep getting an error whenever I try to run 'make'. See
> below for the output of make (./configure returned no obvious errors).
> (cd port; make)
> make[1]: Entering directory `/home/JoshVote/gdal/port'
> /bin/sh /home/JoshVote/gdal/libtool --mode=compile --tag=CXX g++ -g -O2
> -Wall  -DOGR_ENABLED -I/home/JoshVote/gdal/port   -I../frmts/zlib
> -DHAVE_LIBZ -c -o cpl_conv.lo cpl_conv.cpp
> /home/JoshVote/gdal/libtool: 1656: preserve_args+= --tag CXX: not found
> eval: 1: base_compile+= g++: not found
> eval: 1: base_compile+= -g: not found
> eval: 1: base_compile+= -O2: not found
> eval: 1: base_compile+= -Wall: not found
> eval: 1: base_compile+= -DOGR_ENABLED: not found
> eval: 1: base_compile+= -I/home/JoshVote/gdal/port: not found
> eval: 1: base_compile+= -I../frmts/zlib: not found
> eval: 1: base_compile+= -DHAVE_LIBZ: not found
> eval: 1: base_compile+= -c: not found
> libtool: compile: you must specify a compilation command
> libtool: compile: Try `libtool --help --mode=compile' for more information.
> make[1]: *** [cpl_conv.lo] Error 1
> make[1]: Leaving directory `/home/JoshVote/gdal/port'
> make: *** [port-target] Error 2
> The annoying thing is that I have absolutely no problems building gdal under
> my 32 bit linux (Debian) box. I've been doing a bit of googling and have
> come across a similar issue
> http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=621930 that was apparently
> resolved for 1.7.3-2 a few weeks ago, did this ever make it to trunk?
> Works Under - Debian 6.0 (Linux .... 2.6.32-5-686 #1 SMP Wed Jan 12 04:01:41
> UTC 2011 i686 GNU/Linux)
> Fails Under - Debian 6.0.1 (Linux .... 2.6.32-5-amd64 #1 SMP Mon Mar 7
> 21:35:22 UTC 2011 x86_64 GNU/Linux)
> Thanks in advance for any help
> Josh Vote
