[gdal-dev] TIFF with different KEYS_DS
Jorge jormarfe at gmail.com
Mon May 16 19:08:28 EDT 2011
Hello,
Many thanks for your help, but if I want to generate a tiff file which contains multiples images, How I  can do it using gdal? because I know that tiff standard allows to generate multiple images in a single tiff file.
Best regards,
Jorge
El 16/05/2011, a las 18:52, Chaitanya kumar CH <chaitanya.ch at gmail.com> escribió:
> Jorge,
> You can set and retrieve metadata items from a TIFF dataset (TIFF file) using the methods documented in http://www.gdal.org/classGDALMajorObject.html
> On Mon, May 16, 2011 at 9:32 PM, Jorge Martin <jormarfe at gmail.com> wrote:
> Hello,
>        I am interested in writing different Keys_DS in the same TIFF file using gdal library. I only know how to write one Key_DS but I do not know how to include more than one KEY_DS, and I know that TIFF standard allow it. Does anyone know how to implement it with gdal library?
> Many Thanks,
> Jorge
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110517/5d52f4e5/attachment.html
