[gdal-dev] TIFF with different KEYS_DS
Jorge Martin jormarfe at gmail.com
Tue May 17 05:59:04 EDT 2011
Hello Frank,
        TIFF 6.0 specifications has a sub-section in page 16 which is called
"Multiple Image per TIFF file" and there is only a description of this issue
but anything about its implementation:
 "There may be more than one IFD in a TIFF file. Each IFD defines a subfile.
One potential use of subfiles is to describe related images, such as the
pages of a facsimile transmission. A Baseline TIFF reader is not required to
read any IFDs beyond the first one."
        Is it possible to implement it?
Best Regards,
2011/5/17 Frank Warmerdam <warmerdam at pobox.com>
> On 11-05-16 07:08 PM, Jorge wrote:
>> Hello,
>> Many thanks for your help, but if I want to generate a tiff file which
>> contains
>> multiples images, How I can do it using gdal? because I know that tiff
>> standard
>> allows to generate multiple images in a single tiff file.
> Jorge,
> I have skimmed the GeoTIFF driver and it does not seem to support creating
> multi-image files (with special exceptions for overviews and masks).  I
> thought maybe I had implemented a mechanism to add new images to an
> existing
> GeoTIFF file but apparently not.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110517/017061a4/attachment-0001.html
