[gdal-dev] Re: [FWTools] BigTiff problem in experimental FWTools3
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue May 17 08:33:56 EDT 2011
Petteri,
Can you confirm that you have no other libgdal at a different location. The
python script may be loading a different libgdal.
Also check the value of environment variable PYTHONPATH where you use the
FWTools utilities.
On Tue, May 17, 2011 at 3:40 PM, Petteri Packalen <packalen at cs.joensuu.fi>wrote:
> Hello,
> I'm facing a problem related to BigTiff support in experimental FWTools3 on
> Linux. BigTiff support works fine with all compiled programs (e.g.
> gdal_translate, gdalwarp) but not with the python script gdal_fillnodata.py.
> For instance, executing:
>  gdal_fillnodata.py -md 10 unfilled.tif filled.tif
> is terminated by the message:
>  ERROR 1: TIFFAppendToStrip:Maximum TIFF file size exceeded
>  ERROR 1: An error occured while writing a dirty block
> I have tested with versions 3.0.2 and 3.0.6 under 32 and 64 bit Ubuntus.
> Any hint what is going wrong?
> Best regards,
> Petteri Packalen
> Petteri Packalén
> Senior Researcher, Forest Mensuration Science
> University of Eastern Finland
> Faculty of Science and Forestry,
> School of Forest Sciences
> P.O. Box 111
> 80101 Joensuu
> E-mail: Petteri.Packalen at uef.fi
> Phone: +358 13 251 4093
> Room: Borealis 376
> FWTools mailing list
> FWTools at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/fwtools
> http://fwtools.maptools.org/
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110517/15cf40b6/attachment.html
