[gdal-dev] gdal 1.8 tiff
Julien Malik julien.malik at c-s.fr
Tue May 17 10:47:26 EDT 2011
Hello Even,
My apologies for the late reply.
I took the quick and not-so-dirty way : gdal is repackaged in the OTB
ppas, where I have applied the last strategy you mention : I let the
warning about libtiff version mismatch be emitted, but still register
the driver.
Everything is back to normal with this, and the patch is not very intrusive.
Hopefully this will be only temporary, waiting for this "versioned
symbols" solution from the Debian folks, and I will be able to throw
away our specific gdal package soon.
Thanks,
Julien
Le 11/05/2011 20:03, Even Rouault a écrit :
> Le mercredi 11 mai 2011 18:51:07, Julien Malik a écrit :
>> Hello list,
>> I had a bad surprise today using the new gdal 1.8 package available in
>> ubuntugis-unstable :
>> When linked both to tiff v3 and gdal 1.8, the GTIFF driver is disabled
>> with a warning appearing like :
>>      WARNING ! libtiff version mismatch : You're linking against libtiff
>> 3.X but GDAL has been compiled against libtiff>= 4.0.0
>> I understand from frmts/gtiff/geotiff.cpp that this is voluntary (though
>> the warning does not say it actually disables the GTiff driver).
> I'm a bit frustrated... I put this check to avoid bug reports actually ;-) Too
> many people get hurt because of a version mismatch and have a hard tried
> figuring what goes wrong.
>> In my case (building the Orfeo Toolbox library, which has a dependency
>> needing TIFF and GeoTiff, but not gdal), it has the undesirable
>> consequence of breaking TIFF support for our ubuntu packages based on
>> the ubuntugis-unstable ppa
>> (https://launchpad.net/~otb/+archive/orfeotoolbox-nightly and
>> https://launchpad.net/~otb/+archive/orfeotoolbox-stable-ubuntugis).
>> The issue has already been discussed on this list, but just to recall :
>> we had a solution providing usable executables with TIFF support, even
>> though they were linked to the system libtiff and libgeotiff (it
>> involved ensuring the proper link order between '-lgdal' and '-lgeotiff').
>> That's why I think disabling the driver completely is a little hard.
>> In my case it represents a major regression, and I don't have a lot of
>> ideas to work around it...
>> Is it possible to *not* disable the driver, and keep the warning ?
> If your question is "without changing the code ?", the answer is no.
> If Debian/Ubuntu goes into the way of using versionned symbols, they can just
> apply a local trivial patch to disable this check. My rationale is that people
> that want to mix both libtiff 3 and libtiff 4 are considered to be sufficient
> advanced users to make patches to undo the sanity checks if they really know
> what they are doing. IMHO, the default should be to stick to safe settings.
> But perhaps I did go too far and I'm open to suggestions. Changing the
> behaviour of this check is trivial. The difficult part is to figure out the
> expected behaviour and I just don't know what would be the option that would
> satisfy most/all people. One possibility would be to disable the driver unless
> an environment variable GDAL_ACCEPT_MIXED_LIBTIFF_VERSIONS is defined  ?? But
> that seems to a bit too convoluted. Or just emit the warning and still enables
> the driver, considering that the warning is enough and that if people get
> crashes, they would know why. I'm interested by opinion from other people.
> Best regards,
> Even
>> Regards,
>> Julien
>> NB: I filed a ticket in our bug tracker
>> (http://bugs.orfeo-toolbox.org/view.php?id=296), feel free to leave
>> comments there.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
