[gdal-dev] Re: [FWTools] BigTiff problem in experimental FWTools3
Petteri Packalen packalen at cs.joensuu.fi
Tue May 17 15:31:55 EDT 2011
Chaitanya, Frank,
I verified that only one libgdal exists in a system. I have also added
'-co' switch to gdal_fillnodata.py in order to force BigTiff creation
(BIGTIFF=YES). But the problem persists.
However, I think I have traced the problem down to:
   http://svn.osgeo.org/gdal/trunk/gdal/alg/rasterfill.cpp
In lines 458 and 474 temporary GTiff files are created. Also creation
option COMPRESS=LZW is used (not easy to guess whether the file size will
be over 2^32?). In my case the file osValTmpFile increases until its size
goes over 2^32 when the error is emitted by TIFF library. Thus this
temporary file was not created as a BigTiff file.
Can you verify that I'm on the right track?
Best regards,
Petteri Packalen
Petteri Packalen
Senior Researcher, Forest Mensuration Science
University of Eastern Finland
Faculty of Science and Forestry,
School of Forest Sciences
P.O. Box 111
80101 Joensuu
E-mail: Petteri.Packalen at uef.fi
Phone: +358 13 251 4093
Room: Borealis 376
On Tue, 17 May 2011, Frank Warmerdam wrote:
> On 11-05-17 06:10 AM, Petteri Packalen wrote:
>> Hello,
>> I'm facing a problem related to BigTiff support in experimental FWTools3 on
>> Linux. BigTiff support works fine with all compiled programs (e.g.
>> gdal_translate, gdalwarp) but not with the python script gdal_fillnodata.py.
>> For instance, executing:
>> gdal_fillnodata.py -md 10 unfilled.tif filled.tif
>> is terminated by the message:
>> ERROR 1: TIFFAppendToStrip:Maximum TIFF file size exceeded
>> ERROR 1: An error occured while writing a dirty block
>> I have tested with versions 3.0.2 and 3.0.6 under 32 and 64 bit Ubuntus.
>> Any hint what is going wrong?
> Petteri,
> Sorry for the delay in looking into this issue.
> I have tested with FWTools 3.0.6 and I do not encounter any problems with
> the python scripts and support for big tiff files.  In particular I
> created a 4.8GB TIFF file with gdal_translate and then I translated it into
> a new file with gdalimport.py without any problem.
> I looked into libtiff at the message you are seeing and I believe it only
> occurs in libtiff4, so you definately have the BigTIFF enabled TIFF library
> being used at runtime.  But should the file be created as a regular TIFF
> instead of a BigTIFF and yet it somehow runs over the 4GB mark you will get
> this message.
> I suspect that this is what is happening, though it is not immediately clear
> to me how that would happen in the above situation.  Unfortunately
> gdal_fillnodata.py does not provide -co options to pass extra creation options
> to the create function or else you could ensure that the output file is created
> as a bigtiff (using -co BIGTIFF=YES).
> What size is your input file (unfilled.tif)?
> I wonder if you could provide steps by which I could reproduce the problem
> without having to slug multi GB files around?
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> FWTools mailing list
> FWTools at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/fwtools
> http://fwtools.maptools.org/
