[gdal-dev] Having trouble compiling MrSid in GDALv1.8
Paul Meems bontepaarden at gmail.com
Tue May 17 19:04:46 EDT 2011
Thanks Kirk and Chaitanya,
It was indeed GDAL_HOME. I used double quotes around it and after removing
it it is working.
LizardTeck provided some sample data. And I'm using it to check if my
version of GDAL is correct.
I use gdalinfo to check the .sid file and it works. When I do a gdalinfo on
the .las file it is not recognized.
When I do a gdalinfo --formats I see MG4Lidar, but the description states
.sid
Does this mean I didn't configure it right after all?
Thanks,
Paul
2011/5/18 Kirk McKelvey <kmckelvey at lizardtech.com>
> The line it is complaining about is almost certainly the following line,
> where MRSID_DIR is used for the first time.  Not sure how it gets 72.
> What is your value for GDAL_HOME?  There might be some kind of quoting
> issue going on.  Also, I’m not sure I ever tested it with relative paths, so
> that could be it as well.
> *From:* gdal-dev-bounces at lists.osgeo.org [mailto:
> gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Paul Meems
> *Sent:* mardi 17 mai 2011 17:19
> *To:* gdal-dev at lists.osgeo.org
> *Subject:* [gdal-dev] Having trouble compiling MrSid in GDALv1.8
> Hi all,
> I'm trying to compile GDALv1.8 on Win7 using VS2008Pro.
> So far I've added successfully GEOS, cUrl, ECW, Proj.4 and Xerces.
> I'm now trying to add MrSid support.
> I've downloaded the Unified Decode SDK v8 from LizardTech and changed this
> in my nmake.opt:
> MRSID_DIR =    $(GDAL_HOME)\..\LizardTech-SDK\Win32
> When I compile I get an error in line 72:
> fatal error U1023: syntax error in expression
> \GDAL\gdal18\frmts\mrsid\nmake.opt
> I didn't changed this file.
> Lines 64 - 80 are:
> !IF DEFINED(MRSID_DIR)
> # Guard against conflicting configuration.
> !IF DEFINED(MRSID_RASTER_DIR) && DEFINED(MRSID_LIDAR_DIR)
> !ERROR The MRSID_DIR value is redundant or conflicts with the values of
> MRSID_RASTER_DIR and MRSID_LIDAR_DIR.  Please remove one of these values
> from the build configuration.
> !ENDIF
> # If a raster path was not explicitly set, see if MRSID_DIR is one.
> !IF !DEFINED(MRSID_RASTER_DIR)
> !IF EXIST("$(MRSID_DIR)\Raster_ESDK\include\lt_base.h")
> MRSID_RASTER_DIR = $(MRSID_DIR)\Raster_ESDK
> !ELSE IF EXIST("$(MRSID_DIR)\Raster_DSDK\include\lt_base.h")
> MRSID_RASTER_DIR = $(MRSID_DIR)\Raster_DSDK
> !ELSE IF EXIST("$(MRSID_DIR)\include\lt_base.h") ||
> EXIST("$(MRSID_DIR)\include\support\lt_base.h")
> !ENDIF
> !ENDIF
> Line 72 is !IF !DEFINED(MRSID_RASTER_DIR)
> What do I need to do to enable MrSid?
> Thanks,
> Paul
> *Paul Meems *
> Release manager, configuration manager
> and forum moderator of MapWindow GIS.
> www.mapwindow.org
> Owner of MapWindow.nl - Support for
> Dutch speaking users.
> www.mapwindow.nl
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110518/07479c6d/attachment-0001.html
