[gdal-dev] Labeling rasters
Jerl Simpson jsimpson at wxtrends.com
Thu May 19 08:01:26 EDT 2011
Thanks Hernán, that's actually what I'm working on this morning.
2011/5/19 Hernán De Angelis <dhdeangelis.listas at gmail.com>:
> Generic Mapping Tools (http://gmt.soest.hawaii.edu/)
> H.
> 2011/5/16 Jerl Simpson <jsimpson at wxtrends.com>:
>> Ok, thank you.
>> Does anyone else have any suggestions?
>> On Mon, May 16, 2011 at 3:06 PM, Chaitanya kumar CH
>> <chaitanya.ch at gmail.com> wrote:
>>> Jerl,
>>> I'm afraid gdal_rasterize can't do the labelling. You will need a
>>> specialized renderer for that. I'm not familiar with any of the desktop
>>> applications that do this. Perhaps, qgis has a plugin.
>>> On Tue, May 17, 2011 at 1:30 AM, Jerl Simpson <jsimpson at wxtrends.com> wrote:
>>>> I already have the resultant image, it looks great.   Just drawing
>>>> lines on a map.  I'm using a blank image so I can more clearly see
>>>> what's going on.  It's just a black and white image, and that's all I
>>>> want.
>>>> I'm trying to get the contour labeled, so I know which one I'm
>>>> viewing.  So on the 1000 contour, I should see 1000 on the line
>>>> somewhere, and if it's a 547 contour, I should see 547 on the line
>>>> somewhere.
>>>> Is that possible?
>>>> Thanks,
>>>> Jerl
>>>> On Mon, May 16, 2011 at 2:41 PM, Chaitanya kumar CH
>>>> > Jerl,
>>>> > The contour attribute and the Z values are same here. Just one of them
>>>> > is
>>>> > enough.
>>>> > With the Z values near the magnitude of 1000, the burn value of 255 is
>>>> > not
>>>> > going to make much of a difference. Use it if you want to offset any
>>>> > negative Z values.
>>>> > You should mention contour.shp instead of just 'contour' for
>>>> > <src_datasource>.
>>>> > Make sure BLANK.tif doesn't have different extents/projection.
>>>> > Your final image will have a data type of Float64. You may have to run
>>>> > some
>>>> > contrast stretching operations on it.
>>>> > On Tue, May 17, 2011 at 12:04 AM, Jerl Simpson <jsimpson at wxtrends.com>
>>>> > wrote:
>>>> >> Hi guys and gals:
>>>> >> I have something that's evading me.  I have a basic ESRI Shape file
>>>> >> (created using gdal_contour) that I run through gdal_rasterize to
>>>> >> generate very nice looking contour map.  But I want the value of the
>>>> >> contour in there.
>>>> >> I've been trying different things with the -a option, but I can't get
>>>> >> it to work out.
>>>> >> Here's the latest thing I've tried for gdal_rasterize:
>>>> >> gdal_rasterize -a contour -3d -b 1 -b 2 -b 3 -b 4 -burn 255 -burn 255
>>>> >> -burn 255 -burn 255 -burn 255 -l contour contour BLANK.tif
>>>> >> I put an extra burn value in there (have also tried with out) to see
>>>> >> if maybe it was just going in as 0.  BLANK.tif is just a black image.
>>>> >> I'm sure I'm missing something simple, just can't see it.  I thought
>>>> >> the -a would burn the value of "contour" into the raster.
>>>> >> Thanks for any guidance!!
>>>> >> Here's the data from my shapefile:
>>>> >> INFO: Open of `contour/'
>>>> >>      using driver `ESRI Shapefile' successful.
>>>> >> Layer name: contour
>>>> >> Geometry: 3D Line String
>>>> >> Feature Count: 157
>>>> >> Extent: (-0.500000, -89.830132) - (359.500000, 89.144137)
>>>> >> Layer SRS WKT:
>>>> >> GEOGCS["GCS_WGS_1984",
>>>> >>    DATUM["WGS_1984",
>>>> >>        SPHEROID["WGS_1984",6378137,298.257223563]],
>>>> >>    PRIMEM["Greenwich",0],
>>>> >>    UNIT["Degree",0.017453292519943295]]
>>>> >> contour: Real (12.3)
>>>> >> OGRFeature(contour):0
>>>> >>  ID (Integer) = 0
>>>> >>  contour (Real) =     1000.000
>>>> >>  LINESTRING (87.765060240963862 80.0 1000,.....
>>>> >> _______________________________________________
>>>> >> gdal-dev mailing list
>>>> >> gdal-dev at lists.osgeo.org
>>>> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> > Best regards,
>>>> > Chaitanya kumar CH.
>>>> > /tʃaɪθənjə/ /kʊmɑr/
>>>> > +91-9494447584
>>>> > 17.2416N 80.1426E
>>>> This communication is privileged and may contain confidential
>>>> information.  It's intended only for the use of the person or entity
>>>> named above. If you are not the intended recipient, do not distribute
>>>> or copy this communication. If you have received this communication in
>>>> error, please notify the sender immediately and return the original to
>>>> the email address above. © Copyright 2011 Weather Trends
>>>> International, Inc.
>>> Best regards,
>>> Chaitanya kumar CH.
>>> /tʃaɪθənjə/ /kʊmɑr/
>>> +91-9494447584
>>> 17.2416N 80.1426E
>> International, Inc.
International, Inc.
