[gdal-dev] Need some help adding libCurl to GDAL
Even Rouault even.rouault at mines-paris.org
Thu May 19 13:32:09 EDT 2011
Le jeudi 19 mai 2011 10:22:08, Paul Meems a écrit :
> Hi List,
> I'm still working on Win7 with VS2008 and I try to add libcurl to GDAL so
> we can use the new WFS driver.
> Two days ago I already succeeded in compile just libcurl and add it to
> GDAL. But then the WFS driver doesn't work with https links.
> So yesterday I've been trying for almost 10 hours to get libcurl, openssl
> and libssh to compile together.
> I'm using
> http://curl.haxx.se/libcurl/c/Using-libcurl-with-SSH-support-in-Visual-Stud
> io-2008.pdfas a guide and downloaded and installed:
> * ActivePerl
> * OpenSSL
> * libSSH2
> * Netwide Assembler
Did you try Tamas' builds ? It seems they have SSL support according to his
blog entry :
http://szekerest.blogspot.com/2010/12/daily-built-binary-packages-for.html
> I've got the necessary files now. I also did what was suggested in Appendix
> A of the PDF.
> But when I do ogrinfo -ro WFS:https://my.testserver.com I get this
> response: Error returned by server : Protocol https not supported or
> disabled in libcurl
> Today I tried checking if libcurl is configured properly, but I'm lost in
> the non-windows makefile and perl files.
> But because I followed the guide I assume libcurl is correctly build.
> Most likely I need to make additional changes to my nmake.opt for GDAL.
> Currently I have this:
> CURL_DIR =    $(GDAL_HOME)\..\cUrl
> CURL_INC = -I$(CURL_DIR)/include
> CURL_LIB = $(CURL_DIR)/lib/DLL-Release/libcurl_imp.lib wsock32.lib
> wldap32.lib winmm.lib
> I'm also not aware what is best: using a dynamic or static library, but
> that is a more general question ;)
> So please advice me how to enable https.
> Thanks,
> Paul
> *Paul Meems *
> Release manager, configuration manager
> and forum moderator of MapWindow GIS.
> www.mapwindow.org
> Owner of MapWindow.nl - Support for
> Dutch speaking users.
> www.mapwindow.nl
