[gdal-dev] GDAL 1.8.0 and MrSid "no-data" values
Oyvind Idland oyvind.idland at gmail.com
Thu May 26 02:16:11 EDT 2011
should I assume that this error is due to the DSDK 8.x version ?
-- Oyvind
On Mon, May 16, 2011 at 8:30 AM, Oyvind Idland <oyvind.idland at gmail.com>wrote:
> Hi,
> The file I'm using is actually MG2, using only 3 bands.
> Note, thats its the same file I used for testing in 1.7.x aswell.
> - Oyvind
> On Fri, May 13, 2011 at 4:08 PM, Kirk McKelvey <kmckelvey at lizardtech.com>wrote:
>> Is this with MG3 or MG4 files?  MG4 uses an alpha channel instead of
>> nodata, so what you describe would be expected in that case.
>> *From:* gdal-dev-bounces at lists.osgeo.org [mailto:
>> gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Oyvind Idland
>> *Sent:* vendredi 13 mai 2011 04:28
>> *To:* gdal-dev at lists.osgeo.org
>> *Subject:* [gdal-dev] GDAL 1.8.0 and MrSid "no-data" values
>> Hi,
>> I just updated to 1.8.0 from 1.7, using the MrSid DSDK 8.0.
>> In order to handle transparency, i have until now used the metadata values
>> from "IMAGE__NO_DATA_VALUE",
>> and simply masked away pixels.
>> After upgrading, the IMAGE__NO_DATA_VALUE yields nothing, neither is it
>> listed when using gdalinfo.
>> The band->GetNoDataValue() doesn't give me any hints either.
>> Should I handle this in a different way ?
>> -- Oyvind
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110526/7b325f26/attachment-0001.html
