[gdal-dev] GDAL ERS unable to process GDA94 under amd64
Even Rouault even.rouault at mines-paris.org
Fri May 27 13:12:19 EDT 2011
> So my question is how exactly does CPLFindFile discover a filepath and does
> anyone have any clue about why it's not working under Debian amd64?
> Secondly how does "ecw_cs.wkt" end up at /usr/local/share/gdal/?
This is the target directory when building and installing GDAL. This is then
looked for when trying to open of the resource files like ecw_cs.wkt. You can
overrirde this by setting the GDAL_DATA environment variable to point to the
directory where those files are.
