[gdal-dev] Table Names (FGDB)
Duarte Carreira DCarreira at edia.pt
Tue May 31 08:05:40 EDT 2011
Paul,
The schema.table is the most similar to the structure of the fgdb, but may be unwanted complexity. Can this be an option? Like "yes, consider the dataset name"? Or "no, discard dataset name". I can see myself in both situations...
Is the driver read only? If not, what will happen when you try the reverse? From PgSql to fgdb?
Duarte
-----Mensagem original-----
De: Paul Ramsey [mailto:pramsey at cleverelephant.ca]
Enviada: segunda-feira, 30 de Maio de 2011 22:47
Para: gdal-dev at lists.osgeo.org
Assunto: [gdal-dev] Table Names (FGDB)
So, my goal is to map information from FGDB to PostGIS and as much
fidelity as possible.
FGDB includes a class called "Feature Dataset" which is basically a
folder that holds "Feature Class" objects, which map directly to OGR
layers. So the "Feature Dataset" then acts a good deal like a schema
in PostGIS.
I've noticed that the PgSQL driver supports a SCHEMA keyword to allow
you to write to a schema without schema-qualified table names, and
that it also notices when table names are schema qualified and puts
them in the appropriate place. So the name of a layer read from a
schema would show up in OGR as "schemaname.tablename".
In FGDB, we have the "path" of a Feature Class or Table, which looks
like this \FeatureDataset\FeatureClass. Similar to the schema
qualification, yet different. As it stands right now, the
FeatureDataset portion of the path is discarded in the public API, so
that the OGR layer name is just the FeatureClass, with no reference to
the FeatureDataset. That makes it hard to create a mapping from FGDB
(\FeatureDataset\FeatureClass) to PostGIS
(FeatureDataset.FeatureClass).
The FGDB implementation currently returns "GeoDatabase.GetQueryName()"
as the layer name, which "Gets the query name (the name to use in SQL
statements) of a table based on its path". If it returned the path
name, then the FeatureDataset qualification information could be
preserved in other contexts. On the other hand, perhaps the QueryName
is more useful to more users than the path? It looks like the
QueryName is expected to be unique, so probably FeatureClass and Table
names have to be unique regardless of what FeatureDataset they appear
in (true?).
So my options are:
(a) - change the current OGR layer name to the path name
(b) - change the current OGR layer name to a "schema.table" analogue
and handle appropriately
(c) - leave the current OGR layer name as is ("tablename" regardless
of containing folders) and make a FGDB-only method for accessing the
pathname for my particular purposes
Preferences?
P.
