[gdal-dev] Re: Convert from CA83-VF (EPSG 2229) to WGS84 (EPSG 4326) using gdaltransform
kavinmehta kavin at tsswireless.com
Tue May 31 16:06:18 EDT 2011
Thanks Jean-Claude.
I ran the following command:
>ogr2ogr -f "ESRI Shapefile" -overwrite "C:/mapdata/ABC.shp"
"C:/mapdata/ABC.shp" -T_SRS EPSG:4326
and got similar error:
ERROR 4: Unable to open EPSG support file gcs.csv.
Try setting the GDAL_DATA environment variable to point to the
directory containing EPSG csv files.
Failed to process SRS definition: EPSG:4326
How do i say this is my input and this is my output file? if i give an o/p
file name in the above command then it says it does not exist, which is
correct because i want it to create it. hence i gave the same file name with
an overwrite command but it did not work either.
Thanks for your help.
Kavin
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Convert-from-CA83-VF-EPSG-2229-to-WGS84-EPSG-4326-using-gdaltransform-tp6424186p6424310.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
