[gdal-dev] Re: Convert from CA83-VF (EPSG 2229) to WGS84 (EPSG 4326) using gdaltransform
kavinmehta kavin at tsswireless.com
Tue May 31 21:59:09 EDT 2011
HI Frank,
thanks for your help, I did as per your reply but I still get the same error
message:
ERROR 4: Unable to open EPSG support file gcs.csv.
Try setting the GDAL_DATA environment variable to point to the
directory containing EPSG csv files.
Failed to process SRS definition: EPSG:4326
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Convert-from-CA83-VF-EPSG-2229-to-WGS84-EPSG-4326-using-gdaltransform-tp6424186p6425357.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
