[gdal-dev] Kakadu Jpeg2000 driver
Tamas Szekeres szekerest at gmail.com
Tue Nov 1 09:08:35 EDT 2011
It seems kakadu SDK has an extraordinary license which would call for to
compile this driver as a plugin. I have been asked to compile gdal against
this dependency but I'm hesitant to think I could technically distribute
the gdal binaries in such form without adding the related binaries from the
kakadu SDK.
+1 to modify the makefile to compile as a plugin
Best regards,
Tamas
2011/11/1 Even Rouault <even.rouault at mines-paris.org>
> Selon Livneh Yehiyam <yehil at rafael.co.il>:
> > Hi
> > Is it possible to build the JP2KAK driver as a plugin?
> You didn't mention on which OS you want to build it, but I have had a look
> at
> both makefiles, and I don't see any existing support for building as a
> plugin.
> However, I don't foresee any obvious reason why you this would not doable,
> provided that you can tweak the makefile.
> > Thanks
> > Yehiyam
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111101/75024e84/attachment.html
