[gdal-dev] Kakadu Jpeg2000 driver
Livneh Yehiyam yehil at rafael.co.il
Tue Nov 1 09:10:26 EDT 2011
Its gdal 1.8.1 windows x64. I will give it a try based on one of the other plugins.
Sent from my mobile
Subject: Re: [gdal-dev] Kakadu Jpeg2000 driver
Date: 01 נובמבר 2011 13:58
Selon Livneh Yehiyam <yehil at rafael.co.il>:
> Hi
> Is it possible to build the JP2KAK driver as a plugin?
You didn't mention on which OS you want to build it, but I have had a look at
both makefiles, and I don't see any existing support for building as a plugin.
However, I don't foresee any obvious reason why you this would not doable,
provided that you can tweak the makefile.
> Thanks
> Yehiyam
o
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD.
(hereinafter "RAFAEL") contains confidential information intended for a specific individual and purpose, may
constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not
the intended recipient, you should contact us immediately and thereafter delete this message from your
system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this
message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error,
please notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely delete or destroy any and all
electronic or other copies of the original message and any attachments thereof.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111101/26750270/attachment.html
